Author Topic: Quick Question about the U9BL  (Read 1202 times)
Offline craZivn
« on: Thu, 07 April 2011, 15:51:42 »
Hi All,
Considering buying an XArmor U9BL, but I'm curious if it has the steel plate construction, or if the switches are in fact PCB-mounted?
I read the review, which states in one part that the switches are plate-mounted, but mentions later that there is no steel plate. So I'm confused.
CZI
Offline daerid
    • Rossipedia
« Reply #1 on: Thu, 07 April 2011, 15:58:50 »
Could be a plastic plate.
