Author Topic: blue alps  (Read 4043 times)
Offline False_Dmitry_II
blue alps
« on: Sat, 09 April 2011, 02:18:15 »
So, the ALPS wiki says that the reason why blue alps are so awesome is that they have a longer 'switch plate' is what I'll call it. It's supposed to be why blue/orange are smoother than white/black. So If I were to get a orange switches board, and put the click leaf in from whites, would that approximate blues well enough or would that be a terrible horrendous idea that should never be done?
Offline Izza
blue alps
« Reply #1 on: Sat, 09 April 2011, 04:48:54 »
Quote from: False_Dmitry_II;327216
Such things should always be done so long as results are posted here.
[SIGPIC][/SIGPIC]
Offline kps
blue alps
« Reply #2 on: Sat, 09 April 2011, 11:20:38 »
would that approximate blues well enough?
It would. I don't think you could distinguish them in a blind test.
Offline CurtisLeon
blue alps
« Reply #3 on: Sat, 09 April 2011, 19:52:47 »
Thanks for the idea - I've just tried this with my AEK. I think I like the feel of these ghetto blues better than the original Orange myself. New modding project?
Currently Using
Space Invaders: NMB RTRT8255CW+
Black ALPS: Dell AT101W
Foam & Foil: BTC 5339SX
In Storage
White ALPS (complicated): Focus FK-2001, Reveal KB-7061 (Chicony rebrand), PC Concepts KB-7000 (Chicony rebrand)
Orange ALPS: Apple Extended Keyboard (modded to ghetto Blue ALPS)
Peerless: Fujitsu FKB4700
Foam & Foil: LR 69497 (unknown make, terminal keyboard)
Offline ch_123
blue alps
« Reply #4 on: Sat, 09 April 2011, 21:09:20 »
Blue Alps have a different spring, which is quite possibly why they are 10g lighter than Whites.
Offline ch_123
blue alps
« Reply #5 on: Sat, 09 April 2011, 21:32:19 »
I tested a number of the Blue switches, and they were all 60g.
Offline CurtisLeon
blue alps
« Reply #6 on: Sat, 09 April 2011, 22:04:08 »
My modded Orange switches come out to a solid 60g too.
Currently Using
In Storage
Offline aegrotatio
blue alps
« Reply #7 on: Sat, 09 April 2011, 22:05:56 »
Where I'm from, Blue ALPS means Monterey ALPS which means Serious Collectible.
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
blue alps
« Reply #8 on: Sun, 10 April 2011, 00:44:40 »
I think real life blue alps are rarer than montereys by a longshot.
blue alps
« Reply #9 on: Tue, 19 April 2011, 05:06:37 »
Heh, I came up with that before even reading the entire 'blue alps collectors are/aren't crazy' posts. Just the part in the main ALPS wiki. Now I see that the click leaves are identical, which should make it an exact match.
Do white vs black have the same springs? What about orange versus blue? I would bet the orange ones would be the same. If Orange springs have the same extra half coil then this would be completely identical to blue alps except for the color of the slider.
What are pink alps? They're barely a footnote in the wiki, and I'm trying to find out if they have the grey longer switch plate too.
Offline CurtisLeon
blue alps
« Reply #10 on: Tue, 19 April 2011, 16:35:34 »
Apparently pink ALPS are just black ALPS with the grey switch plate. Don't know why people rave over them so much. At least orange ALPS feel significantly different.
Currently Using
In Storage
Offline ch_123
blue alps
« Reply #11 on: Tue, 19 April 2011, 18:42:57 »
Quote from: aegrotatio;327743
Montereys are not Alps switches. They are clones. Good ones, but nowhere near as interesting as the complicated Blue Alps.
Offline The Solutor
blue alps
« Reply #12 on: Tue, 19 April 2011, 18:50:46 »
Quote from: ripster;327778
Most of the interesting stuff happens AFTER actuation in the Grey Switch Plates vs White Switch Plate with Whites vs Blues.
Would be interesting to know if those graph are showing the average of a decent number of switches or are just one test per switch.
The testing methodology can change a lot. There can be a lot of difference from key to key even in a brand new keyboard.
Offline Jim66
blue alps
« Reply #13 on: Tue, 19 April 2011, 20:09:28 »
Quote from: ripster;333731
I don't know much about ALPS Pinks despite repeatedly asking here what they are like (if they responded I would have put it in the Wiki).
I'm about to solder some pinks back into a M0116 in the next couple of days so I'll let you know... Last time I tried them I wasn't impressed (I was really into dampened whites at the time). We shall see.
blue alps
« Reply #14 on: Tue, 19 April 2011, 21:13:20 »
Excellent. Be sure to take pictures of them and stuff (IIRC, you did some of the other pictures). At the moment I only have the board that I would use for donor click leaves, so I asked before even getting anything else.
Offline Pylon
blue alps
« Reply #15 on: Wed, 20 April 2011, 08:16:32 »
What's the difference between pinks and oranges?
