Author Topic: The "What keyboard is this"  (Read 6926 times)
Offline kaiserreich
  • HHKB Elite
« on: Mon, 11 April 2011, 01:07:23 »
I got this from a my friend's storeroom
It looks like some mechanical switch over rubber dome, but I cannot find a lot of info about this keyboard, which use AT connectors. I found out the brand name is "Legend" and that's about it. Can anyone help?
EDIT: I disassembled the keyboard and it seems it a plunger thing over a whole sheet of rubber dome with metal back plates. This is a helluva rubber dome keyboard with double shot keycaps(?), 1 plastic plate, 1 metal back plate.
« Last Edit: Mon, 11 April 2011, 07:55:24 by kaiserreich »
Offline kaiserreich
  • HHKB Elite
« Reply #1 on: Mon, 11 April 2011, 07:08:24 »
I opened it all up, there's no PCB except a the controller circuit PCB
The matrix are just a thin plastic film you find in cheap rubber domes.
The structure is roughly like this
Keycap
plunger
membrane
film
metal plate
No springs. I had it thoroughly cleaned, only to find out that it was not really nice to type on. My cheapo logitech feels better than it.
« Last Edit: Mon, 11 April 2011, 07:19:46 by kaiserreich »
Offline Reaif
« Reply #2 on: Mon, 11 April 2011, 13:19:31 »
Sounds like old-rubber-dome effect.
Currently own:
Das S Ultimate with Browns
Cherry G84-4100 with ML Linear switches
Memorex Telex with NMB Space Invaders
Leopold with Blues
Offline Boutros
« Reply #3 on: Mon, 11 April 2011, 14:01:10 »
Looks like rubber dome with sliders that allow them to use ALPS compatible keycaps.
Offline kaiserreich
  • HHKB Elite
« Reply #4 on: Mon, 11 April 2011, 22:13:28 »
Well the keys look double-shot, I figured it might worth the trouble of cleaning it or something.
Offline kaiserreich
  • HHKB Elite
« Reply #5 on: Mon, 11 April 2011, 22:24:02 »
They are truly paper thin. I broke one key while trying the remove the stabilizer/white plastic thingy on the keys with a screwdriver. It did not seem like a bad idea until the thing broke.
Anyway I am curious, are rubber domes with double shots a dime a dozen in the old days?
