Author Topic: What kind of keyboard is this?  (Read 1497 times)
Offline nilzie
« on: Tue, 12 April 2011, 15:01:01 »
I found this keyboard recently, but I have no idea what kind it is. Can you guys help me out?
Offline pitashen
« Reply #1 on: Tue, 12 April 2011, 15:33:23 »
Dome
Offline escargot
    • http://escargot.ventdaval.com/
« Reply #2 on: Tue, 12 April 2011, 15:52:00 »
It looks a bit like the Sun 7 rubber dome parts. Which I think, if you can deal with the mushiness, it's a good keyboard.
Offline The Solutor
« Reply #3 on: Tue, 12 April 2011, 15:53:18 »
Quote from: ripster;329414
If you press the Coffee button what happens?  Does it wake up the PC or give you the runs?
If the coffe button really works I'll left the mech wagon quickly :biggrin:
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #4 on: Tue, 12 April 2011, 17:04:10 »
The construction looks pretty Fujitsu-ish... didn't they make those Sun 'boards anyway?
Offline The Solutor
« Reply #5 on: Tue, 12 April 2011, 19:56:50 »
I have a type 4 (built in US) US keymap with the right international enter, and is a reversed rubber dome.
And a type 6 (made in Malaysia) US keymap with the wrong American enter, which seem a plain rubber dome, but has nothing to do with the KB shown in the photo.
Anyway the are both nice looking, but crap keyboards.
Offline CurtisLeon
« Reply #6 on: Wed, 13 April 2011, 04:22:55 »
Rubber dome with a slider.
Currently Using
Space Invaders: NMB RTRT8255CW+
Black ALPS: Dell AT101W
Foam & Foil: BTC 5339SX
In Storage
White ALPS (complicated): Focus FK-2001, Reveal KB-7061 (Chicony rebrand), PC Concepts KB-7000 (Chicony rebrand)
Orange ALPS: Apple Extended Keyboard (modded to ghetto Blue ALPS)
Peerless: Fujitsu FKB4700
Foam & Foil: LR 69497 (unknown make, terminal keyboard)
« Reply #7 on: Wed, 13 April 2011, 05:57:28 »
I agree with that it looks like a Fujitsu rubber dome keyboard -- the slider, the look of the rubber dome and the right border.
The Fujitsu FKB8811 matches what you can see in the image, but perhaps there are other keyboards that do too.
Quote from: keyb_gr;329535
I am sure they did. The sliders and key caps are interchangeable between my Sun Type 5c and
Fujitsu FKB8738
and the rubber dome sheets look similar too. The key caps on the Sun keyboard are of better quality: thicker, pad printed and sharper edges. Unfortunately, the keys on the bottom row are a different size.
« Last Edit: Wed, 13 April 2011, 06:04:39 by Findecanor »
Offline nilzie
« Reply #8 on: Wed, 13 April 2011, 06:51:56 »
Thanks for the answers. I thought it was a nice expensive keyboard. :(
It's made in Malaysia btw.
Offline What is X?
« Reply #9 on: Wed, 13 April 2011, 07:07:00 »
Quote from: nilzie;329905
bit of a contradiction in terms isn't it :p
Offline kaiserreich
  • HHKB Elite
« Reply #10 on: Wed, 13 April 2011, 09:20:07 »
What's wrong with being made in Malaysia?
They make good quality stuff in China, and low quality imitation stuff too. I don't see you complaining about that
