Author Topic: Need 2xDVI to DVI device  (Read 3895 times)
Offline ironman31
« on: Fri, 15 April 2011, 21:47:44 »
I would like to be able to plug my ps3 and computer into said device and plug the other end to my monitor, and be able to switch between which one will display on the monitor. Any known products that aren't ridiculously expensive? I'm pretty sure what I need is a DVI KVM, but it doesn't seem to exist in the under 50 USD range
« Last Edit: Fri, 15 April 2011, 22:05:17 by ironman31 »
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/ATNoppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline ironman31
« Reply #1 on: Fri, 15 April 2011, 22:17:31 »
good idea, thanks. I'll probably do that if my new monitor ends up coming in.
Keyboards:
Pointing Devices:
Offline ironman31
« Reply #2 on: Fri, 15 April 2011, 22:41:51 »
Keyboards:
Pointing Devices:
Offline ironman31
« Reply #3 on: Tue, 10 May 2011, 18:40:21 »
This was actually a terrible idea, lol. But I should have caught it before hand. Apparently HDMI doesn't allow PC resolutions such as 1680x1050. I guess I might try to sell it here if anyone is interested.
Oh, and 24 AWG is definitely way too big of cables if anyone was wondering.
« Last Edit: Tue, 10 May 2011, 19:24:33 by ironman31 »
Keyboards:
Pointing Devices:
Offline bhtooefr
    • bhtooefr.org
« Reply #4 on: Wed, 11 May 2011, 05:29:53 »
HDMI allows the same resolutions as single-link DVI, which goes up to 1920x1200 60 Hz.
The problem is, cheap HDMI gear might not support the higher bandwidths required for any more than 1920x1080 30 Hz.
Offline ironman31
« Reply #5 on: Wed, 11 May 2011, 07:03:39 »
The cables I have are pretty thick. How would I get the other resolutions to transfer through?
Keyboards:
Pointing Devices:
Offline ironman31
« Reply #6 on: Wed, 11 May 2011, 09:27:21 »
monoprice 4x1 and a gtx 285
Keyboards:
Pointing Devices:
