Author Topic: Is Noppoo Choc Mini compatible with Linux  (Read 7177 times)
Offline khunny7
« on: Sun, 17 April 2011, 16:13:30 »
I read the description saying that it does not work on Mac.
I don't know why but I assumed that it would work with Linux(I wasn't thinking.)
I purchased the keyboard and I came to realize that Linux is closer to Mac than Windows.
So, does anybody know if it would be compatible with Linux?
If not, is there a workaround solution to this? Thank you.
Offline RiGS
« Reply #1 on: Sun, 17 April 2011, 16:39:42 »
It works on Linux just fine.
Offline khunny7
« Reply #2 on: Sun, 17 April 2011, 16:41:00 »
Great! thanks.
Offline RiGS
« Reply #3 on: Sun, 17 April 2011, 16:52:22 »
You are Welcome!
Offline keyboardlover
« Reply #4 on: Sun, 17 April 2011, 20:59:41 »
RiGS, do you have a link to the source of that information?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #5 on: Sun, 17 April 2011, 21:53:00 »
I just plugged mine into my Gentoo running laptop and yes it works just fine.
Filco w/ Imsto thick PBT
Offline khunny7
Thanks for the confirmation.
« Reply #6 on: Sun, 17 April 2011, 22:52:28 »
Quote from: alaricljs;332492
I wonder if it would work with my android tablet too.
Offline Grimey
« Reply #7 on: Mon, 18 April 2011, 01:54:10 »
Quote from: khunny7;332517
That is something I would be interesting in as well.
Erlang your pants off
Offline cbf123
everything is compatible (though sometimes with effort)
« Reply #8 on: Mon, 18 April 2011, 10:35:33 »
Linux will use any keyboard mapping you tell it to, and you can customize it as much as you like.
The keyboard will output scancodes, which are then mapped to keycodes, which are then mapped to characters or actions.  Both the scancode/keycode and keycode/character(or action) mappings are customizable under Linux.
Daily drivers are:
Microsoft Natural (the original, and still going strong)
Microsoft Natural Elite
Offline alaricljs
« Reply #9 on: Mon, 18 April 2011, 10:43:04 »
cbf123 - the issue with the Noppoo is that it presents itself as multiple keyboards.  For some reason OSX really doesn't like that.  Anyone try BSD ?
Offline dracaXL
    • http://www.technickal.org
« Reply #10 on: Mon, 18 April 2011, 13:40:43 »
My Noppoo works fine under Ubuntu except for specific LEDs not being activated (scroll / switch / caps - num lock works fine)
Filco Majestouch Linear (i.e. MX Blacks) | Noppoo Choc Mini (MX Browns) | TVS Gold Bharat (MX Blue) | VorTex KBC Poker* (MX Red)
Intel Core i7-2600k | Gainward GTX 580 GOOD | 8GB XMS3 DDR3 RAM | Gigabyte P67-UD4 | Asus Xonar Essence ST | NZXT Phantom | KRK RP5 G2 w. Wharfedale SW150
*pre-ordered
Offline cbf123
« Reply #11 on: Tue, 19 April 2011, 11:49:22 »
Quote from: alaricljs;332749
Linux handles multiple keyboards (and multiple mice for that matter) just fine.  X just multiplexes all the different inputs.
Daily drivers are:
Offline alaricljs
« Reply #12 on: Tue, 19 April 2011, 12:35:16 »
Quote from: cbf123;333472
I had no question that it would work in linux.  I simply ran the test to have the empirical proof.  My question is what the problem is with OSX and (being BSD/Mach based) has anyone tried another flavor of BSD?
Offline heedpantsnow
  • Old enough to know better
« Reply #13 on: Wed, 20 April 2011, 14:13:25 »
any updates on this?
I'm back.
Offline alaricljs
« Reply #14 on: Wed, 20 April 2011, 15:30:03 »
What is there to update?  OP's question is answered.
« Reply #15 on: Wed, 20 April 2011, 15:56:15 »
Quote from: ripster;334386
I think he's talking more about the OSX incompatibility.
To be frank I'm a bit perplexed why it isn't fixed by now as well.
This.
Also, about the Caps/Scroll lock possibly not working outside of Windows.  Anyone else have experience with that?
I'm back.
Offline molto
    • http://www.friv.gs
« Reply #16 on: Sun, 11 December 2011, 01:25:32 »
Quote from: heedpantsnow;334402
This.
Caps lock works but the led doesn't show (not sure about scroll lock, I don't use it). In addition, Ctrl-Alt-F1 switching doesn't work, which means I can't switch out of X or to a separate X instance without plugging in another keyboard.  Also the Sysrq functions don't work, which are very handy in safely shutting down an unstable system.
All of the above do work in the linux console, which suggests that this is an Xorg issue. I have tried using evdev and the old keyboard driver, but neither fixes the issue.
y8 | Miniclip | y3 | friv | ben10 | y8 | kizi | y8 | y3  | y8 | pogo
Offline iMav
  • geekhack creator/founder
« Reply #17 on: Sun, 11 December 2011, 10:45:09 »
I used the Noppoo under Ubuntu and SuSE without issue (also under Win 7 and XP).
OS X issues were why I sold mine.
Offline stfsux
Re: Is Noppoo Choc Mini compatible with Linux
« Reply #18 on: Sun, 27 January 2013, 20:13:32 »
Same issue on Debian Squeeze.
Another weird thing is that leds work in openbsd via virtual machine...
It might be a driver issue. As i remember about PS2 keyboard protocol, turning on/off caplock led is done by your computer (host-to-device command), not your keyboard.
I'll take a look about that.
EDIT: Well, the noppoo choc mini is not really supported on Debian Squeeze.
About leds issue, there is a way to make caps lock led working:
Code: [Select]
setxkbmap -option ctrl:swapcaps
It will swap ctrl and caps key function but led still works now...
BTW OpenBSD 5.2 fully support n-key rollover USB keyboard (http://www.mail-archive.com/misc@openbsd.org/msg117150.html), that's certainly why everything work well (leds, ctrl+alt+FN, etc.).
« Last Edit: Sun, 27 January 2013, 23:39:55 by stfsux »
« Reply #19 on: Mon, 28 January 2013, 16:05:30 »
For anyone interested: I use a Filco TKL with Xubuntu (ie a Ubuntu variant). Everything works perfectly except for the Scroll Lock - at least the LED doesn't come on; I'm not really sure what the key is supposed to do.
Offline davkol
  •  Post Editing Timeout
« Reply #20 on: Tue, 29 January 2013, 11:52:41 »
I prefer LEDs turned off, but I don't think the light on Caps Lock didn't work for me. I won't test it, because I'm too lazy to switch keyboard layout from Colemak to QWERTY (hint: Caps Lock remapped to Backspace).
Choc Mini works perfectly for me (on Linux Mint 13/14) except numpad layer on USB (works fine with PS/2).
