Author Topic: Bought a Filco... Thinking about converting Caps Lock to Ctrl  (Read 3780 times)
Offline insaneirish
« on: Sun, 17 April 2011, 18:52:19 »
Hey all. Just bought my first 'real' keyboard (a Filco).
One thing that drives me absolutely crazy is having the Caps Lock key actually be Caps Lock. I spent quite a lot of time using keyboards where the Ctrl key is where Caps Lock is now on most keyboards.
Sometimes you can swap these via software and everything works a charm. However, at work, we use thin clients that connect back to our actual desktops in a data center. The thin client intercepts the keystroke too early on in the process to remap the Caps Lock key to Ctrl.
So, I'm thinking about a hard hack. Does anyone think it's feasible to unsolder the Caps Lock switch from the PCB and re-connect it to the pins for Ctrl? This would solve all my problems.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Sun, 17 April 2011, 20:01:03 »
Have you tried AutoHotKey?  Unless your thin client is using DirectInput there is no reason for AutoHotKey not to work.
Filco w/ Imsto thick PBT
Offline mattdurham
« Reply #2 on: Sun, 17 April 2011, 21:08:55 »
What OS are you operating under? Also what sort of OS are you connecting to? I have had some trouble in RDPing from OSX into a Win7 box and then accessing a XP VMWare instance. But other than that specific and fubar example I have had good look under a variety of platforms.
mattdurham
Offline n19htmare
« Reply #4 on: Sun, 17 April 2011, 22:25:44 »
Quote from: ripster;332500
Scrape the traces and spaghetti wire it.
Pictures of how to open Filco and what's inside are here.
For future reference when I say "are here" that means there is an invisible link there.  This is not a sophisticated troll.
Mind Reader....
Offline Chobopants
« Reply #5 on: Sun, 17 April 2011, 23:30:41 »
I love the new theme jokes, it brings some levity to the theme downgrade. :)
Also, re: the topic...
On OS X and Linux you can very easily remap the keys. I haven't done it yet in Windows because it's a bit goofier and less integrated to the OS.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline daerid
    • Rossipedia
« Reply #6 on: Mon, 18 April 2011, 00:53:10 »
You can do it with Registry Hacking. However, I find KeyTweak to be much easier for performing semi-hard key remapping
Offline Tony
« Reply #7 on: Mon, 18 April 2011, 04:18:21 »
Autohotkey usually works, have you tried it?
Offline insaneirish
« Reply #8 on: Mon, 18 April 2011, 19:29:33 »
Thanks all for the AutoHotkey suggestion. While registry remaps did *not* work, AutoHotkey did! No hard hack needed.
Offline alaricljs
« Reply #9 on: Mon, 18 April 2011, 20:10:15 »
Quote from: ripster;333089
Great!  Thin clients are the future.
Or is it cloud computing?
Never can remember.
Thin clients accessing a cloud of boobs.
Offline insaneirish
« Reply #10 on: Mon, 18 April 2011, 20:16:33 »
Never can remember.
What's old is new again. I don't enjoy using Windows, but the thin client works well enough. I travel frequently between buildings in NYC and being able to pick up my desktop right where I left it is nice.
That said, I had the same ability 8 years ago on a Sun Ray terminal (which is where I picked up my habit of expecting the Ctrl key next to the A).
