Author Topic: Keycaps getting shiny  (Read 10765 times)
Offline sequencius
« on: Sun, 17 April 2011, 23:03:02 »
I bought a used Black Cherry ML 4100 and the keys show that shiny-ness that happens on the surface of the keys where usage is heavy...like the right side of the spacebar.
It's pretty ugly. I'm assuming there's really nothing you can do about it other than switch keycaps which I'm sure is pretty hard to find for this keyboard?
Does this happen to all keyboards after awhile? Or is this one just made with cheap plastic or something...
Offline Lpb45
« Reply #1 on: Sun, 17 April 2011, 23:08:50 »
all keys given enough time some are better then others, checkout the wiki for more info.  Or just wait for Ripster to go into more detail.
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline Mr. Perfect
« Reply #2 on: Sun, 17 April 2011, 23:24:57 »
You have two options: sandblast the keys back to a rough texture, or polish them all to a shine. Everyone takes the first choice.
My old Cherry POS board has an awful lot of smooth keys, and they're actually kind of sexy feeling. It's a texture not unlike a marble counter top or fine furniture with a high gloss finish. Every once in a while I hit an unused key, which just feels like course plastic... :brick:
I'm weird though. Everyone else hates smooth keys. :pound:
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline Megaweapon
« Reply #3 on: Sun, 17 April 2011, 23:25:11 »
Fight shiny with shiny:  Titanium keycaps.
They were $9 per key (except for the space bar) on the KBC group buy...
Ancer Research Groop DFK191ABA11 • IBM Model M13 Part 92G7461 (white) • Rosewill RK-9000
Matias Tactile Pro 3 • Apple Extended Keyboard II (ALPS)
• Rosewill RK-9000I
Offline CurtisLeon
« Reply #4 on: Sun, 17 April 2011, 23:25:32 »
PBT and POM keycaps wear much less than normal ABS keycaps, like the one on your board. Unfortunately, I believe double shot injection molding can't be used with PBT for some reason or another and I've never heard of a POM double shot either.
Currently Using
Space Invaders: NMB RTRT8255CW+
Black ALPS: Dell AT101W
Foam & Foil: BTC 5339SX
In Storage
White ALPS (complicated): Focus FK-2001, Reveal KB-7061 (Chicony rebrand), PC Concepts KB-7000 (Chicony rebrand)
Orange ALPS: Apple Extended Keyboard (modded to ghetto Blue ALPS)
Peerless: Fujitsu FKB4700
Foam & Foil: LR 69497 (unknown make, terminal keyboard)
Offline False_Dmitry_II
« Reply #5 on: Sun, 17 April 2011, 23:34:59 »
Supposedly something about people using the keys makes it wear faster or less. I've never caused a shiny key yet. Not even on cheap rubber dome boards, they seem to last me an infinite amount of time like anything else.
Offline Tony
« Reply #6 on: Mon, 18 April 2011, 04:15:47 »
Keycaps become shiny after heavy use with oily fingers. For a change, wearing gloves and washing hands before typing could help.
Or better, touch type and never look at keyboard while typing, you will be less concerned about shiny keycaps.
Offline liist
« Reply #7 on: Mon, 18 April 2011, 05:20:32 »
With my heavy use typing on the computer as fast as we can constantly, my hands get sweaty and the keyboard shined up really fast. It all depends on how greasy your hands are and how hard you kit the keys.
Kinesis Advantage, Filco Majestouch-2 104, Unicomp Spacesaver with blank keys, Several IBM Model M\'s, two Microsoft keyboards (forever retired)
Offline gilgam
« Reply #8 on: Mon, 18 April 2011, 05:56:54 »
Sandblasting with 80-120 sandpaper works fine. I've done a whole 105 set of yellow/shiny keycaps and it gives a nice feeling (like pbt realforce/HHkb).
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
Offline Lpb45
« Reply #9 on: Mon, 18 April 2011, 06:37:22 »
Quote from: CurtisLeon;332534
The titanium keys were actually 17 per key and the spacebar is 100.
Offline kbdfr
« Reply #10 on: Mon, 18 April 2011, 06:51:02 »
Quote from: Mr. Perfect;332532
Not everyone ;-)
Rough keys keep abrading your fingertips.
They slow down your typing by preventing your fingers from gently gliding on their surface.
They are more difficult to clean than smooth keys.
They make your keyboard look like it's just a matter of showing off.
Smooth keys are the witness of your hard work, the companion of your busy hours.
They show scars you inflicted on them.
They tell the story of a long lasting symbiosis, I would even say: of a friendship.
And I would never tell a friend: "If you don't undergo cosmetic surgery, I'm not interested in your friendship any more".
Sandblasting - pah!
Offline Peter
« Reply #11 on: Mon, 18 April 2011, 09:43:41 »
Quote from: Lpb45;332637
So they've got a Gucci-logo somewhere or what ?
Offline Ascaii
« Reply #12 on: Mon, 18 April 2011, 14:01:11 »
Stop with the advice to use mx caps or sandpaper his caps.
First off check which model g84-4100 you have. is it a g84-4100 S/L,P model?
If it is S or L get some 1000/1200 grain fine Sandpaper and gently rough the top. If it is a P model, dont use sandpaper or you will have no letters left. Youll just have to live with that.
Remember guys, this uses small ML switches, so only g84-4100 caps will fit. No titanium, no mx stems, just g84-4100.
Offline Chobopants
« Reply #13 on: Mon, 18 April 2011, 15:04:00 »
I like my shiny keys actually, means I actually use my boards instead of collect them. :)
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline Lpb45
« Reply #14 on: Mon, 18 April 2011, 15:40:58 »
I didnt suggest Titanium keys I was just correcting the price.
Offline NimbleRabit
« Reply #15 on: Mon, 18 April 2011, 17:26:42 »
I wouldn't mind shiny keys as much if they were all equally shiny; it has more to do with my desire for uniformity than anything else.  Those keys really stick out, not just in how they look but in how they feel, and that's super annoying to me.
