Author Topic: Removing ISO enter key  (Read 6484 times)
Offline Phaedrus2129
« on: Mon, 18 April 2011, 16:55:45 »
Anyone have any advice on removing a Cherry-stabilized, ISO form enter key? My keypuller won't fit it (ring style).
I'm doing the dental band mod on my G80 and I've got all of the alphanumerical group done but the enter key.
For the record, it does make the keyboard slightly quieter, but I don't know if the effect is the worth the $10 it cost me.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Mr. Perfect
« Reply #1 on: Mon, 18 April 2011, 17:08:09 »
Unbent paperclips is what I used. Custom wire puller!
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline JBert
« Reply #2 on: Mon, 18 April 2011, 17:18:58 »
Doing it the MacGyver way I take a piece of string and make a key pulling rig by tying a multi-loop knot.
Since this doesn't need any fancy knot, you can actually do this by tying an overhand loop, then pulling one of the ends through the loop and back up. You should now have 2 loops.
Once you got a string with two loops in it, take two popsicle sticks. Place one loop in the gap between backspace and the enter key and push it down with the popsicle stick. Pull the loop to the bottom edge of the keyboard so it will hook under the key and make sure it can't come back up the gap by pushing the stick to the bottom.
Take the second stick and push the second loop between the enter and right shift. Pull the loop to the top edge and keep it in place with the stick.
Now the rig should be stuck under the key. Pull the ends up whilst making a circular motion to wiggle the stabilizer and key stems.
EDIT: This works great on spacebars too, even those with really tough vanilla G80-3000 keycaps - forget about two wire key pullers when you can do it cheap and sound!
« Last Edit: Mon, 18 April 2011, 17:27:10 by JBert »
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline The Solutor
« Reply #3 on: Mon, 18 April 2011, 19:28:55 »
Quote from: ripster;332984
That key is pretty big.
Mine was damn tightly fitted, came off with the whole stem.
Offline The Solutor
« Reply #4 on: Mon, 18 April 2011, 20:01:57 »
Quote from: ripster;333073
On a Cherry MX G80?  That would be pretty unusual but I'm sure it happens.
Brand new G80 board, white switch donor.
BTW, the stem came off with the upper part of the switch housing. ( One step less in this long work :laugh:)
Offline JBert
« Reply #5 on: Tue, 19 April 2011, 16:07:39 »
Actually, the original Cherry caps my G80 came with were a pain to remove without a wire keypuller. I've tried, and each of the stabilized keycaps would open up like The Solutor said.
Hence why I switched to the rope key puller.
The storage list:
[/SIZE]
« Reply #6 on: Tue, 19 April 2011, 17:53:33 »
The string idea sounds pretty good, but I don't have any string. Keeping with the dental theme I could use some dental floss... But that sounds painful on the hands.
I'll search around the house and see what we've got.
I may also try double banding the main alphanumeric section to see if I can get it even quieter.
Offline The Solutor
« Reply #7 on: Tue, 19 April 2011, 18:03:24 »
This is what happens with the brute force approach (nothing broken, just dismantled)
Offline The Solutor
« Reply #8 on: Tue, 19 April 2011, 18:12:55 »
Quote from: ripster;333703
Hmm.... sounds like I need to redo my MX Keypulling guide a bit and no longer call the Cherry MX G99 stabilizers "foolproof".
It's as if the metal bar caught the prongs or something and pulled the top off.
Now I did it  purposely, just to take a photo, the first time the stabilizer remained in place.
Simply the key crossed hole are tighter than the ones present on the other large keys, and tool or not if the stem is "glued" to the keycap there's little one can do to extract it cleanly.
Maybe just a batch of enter keys with too large tolerances.
Offline The Solutor
« Reply #9 on: Tue, 19 April 2011, 18:24:35 »
Quote from: ripster;333711
Actually in physics terms it's because of the three structural members in a close array.  Like molecules.
Yes but there are 4 of them on the kb...
In porn terms it's because you have three members...
In porn term, I think that the enter key is just more "innocent", likely the brown stem also matters :laugh:
« Reply #10 on: Wed, 20 April 2011, 11:42:02 »
I've tried experimenting a little bit. I tried using two bands on one key. I've found that that tends to increase the force required, and perhaps slightly decreases travel. It doesn't have much impact on noise. I'm not a fan of the effect. However, I've found that it does still decrease noise when done to stabilized keys for some reason, and the increase in force generally isn't as noticeable.
Offline gilgam
« Reply #11 on: Wed, 20 April 2011, 15:57:48 »
same thing when i removed an iso enter key on a new cherry white/clear. the top stabilizer came with the keycap ...
It was very easy to clip it back, more fear than real damage
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
