Author Topic: Mouse with a thumbscroll?  (Read 15558 times)
Offline whizz
« on: Mon, 18 April 2011, 17:15:58 »
Hi guys,
I am using Logitech MX revolution now.
This mouse has a thumbscroll. I have mapped ctrl+tab; ctrl+shift+tab; ctrl+w on that wheel, so I can switch between tabs in all programs like firefox, photoshop etc. I LOVE this feature, and when I am using a different mouse I want to kill myself because of frustration. The problem is, that this mouse is wireless, and I hate when the batteries are empty, because I cannot work.
So I am looking for some new mouse, most likely wired, which has some kind of thumbscroll as well. But I cannot find any - only R.A.T. 7 but it is a bit different and you cannot have that third button (ctrl+w).
Can anybody help? I am not gaming, I am photoshoping. Thanks.
Filco MX Brown Tenkeyless + Filco MX Brown Numberpad
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #1 on: Tue, 19 April 2011, 10:22:52 »
Elecom M-DWUR
[ Attachment Invalid Or Does Not Exist ] 17426[/ATTACH]
A4Tech Opto325
[ Attachment Invalid Or Does Not Exist ] 17425[/ATTACH]
A Ghost From The Past
Offline whizz
« Reply #2 on: Tue, 19 April 2011, 11:11:10 »
ripster: yeah, the spare one is also a solution. BTW this mouse has accumulators, so you cannot change batteries. You have to charge it in a dock.
soulhnuter: thanks, I will check them. So little info about them on a first check
Offline The Solutor
« Reply #3 on: Tue, 19 April 2011, 18:57:31 »
Quote from: whizz;332996
Hi guys,
Remember that the logitech lacks the middle click button, so the rat would be just fine, two commands on the thumb wheel, a third on the middle click
Offline Brodie337
« Reply #4 on: Wed, 20 April 2011, 03:20:46 »
I'm fairly certain that the Logitech scroll wheel clicks just like any other.
Offline The Solutor
« Reply #5 on: Wed, 20 April 2011, 06:20:56 »
No, it doesent.
in both MX 1000 and VX nano, pushing the wheel toggles the inerthial function
Offline Brodie337
« Reply #6 on: Wed, 20 April 2011, 06:46:13 »
Ah ok. The only other mice I've seen with the inertial scroll have had the toggle switch behind the wheel or underneath the mouse. I'd have to have a middle click on a mouse.
Offline The Solutor
« Reply #7 on: Wed, 20 April 2011, 06:50:51 »
Indeed I haven't bought the Mx 1000, and I returned the nano, because I find the lack of middleclick hideous.
At the time I bought the VX revolution (switch on bottom), and now I'm using the great M705 Marathon, switch on top.
Offline Brodie337
« Reply #8 on: Wed, 20 April 2011, 07:03:17 »
The whole hyperscroll thing combined with the relatively high pricing of Logitech mice here in Aus has pretty much turned me off them for good.
Offline whizz
« Reply #9 on: Wed, 20 April 2011, 07:11:49 »
The problem with the scroller on Logitech is, that even that the mouse is very comfortable at all, the scroll wheel is not - middle clicking and left/right clicking is strange.
Offline The Solutor
« Reply #10 on: Wed, 20 April 2011, 07:19:17 »
Quote from: whizz;334085
Th M705 is just perfect, the wheel behavior can be changed with a button on the top, w/o having to interrupt the work and w/o loosing the middle click, is not too big like the MX 1000, not too small like the VX nano, has the unifying receiver, and the battery swap happen every glacial era.
Last but not least, now costs just 39 euro or American dollars wich is really a good price given the product's quality
Offline sordna
« Reply #11 on: Wed, 20 April 2011, 10:05:59 »
Actually I LOVE hyperscroll. I have an M500 and often turn hyperscroll on (for long web pages). Yes, middle clicking is iffy, so what I did was map the left lean of the scrollwheel to do middle click as well. It's very easy and light as a feather to do left-lean click, much better than pressing the scrollwheel down.
Offline The Solutor
« Reply #12 on: Wed, 20 April 2011, 10:10:24 »
I forgot.
The middle click function, for some reason, get worse if the logitech drivers are used (it scrolls a bit before clicking) but is perfect if the default windows drivers are used.
So, is way better to use the default windows drivers and use an alternate sw to map the additional buttons.
Offline marvkip
« Reply #13 on: Wed, 20 April 2011, 11:52:10 »
are those sanwa buttons? what are they there for?
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #14 on: Wed, 20 April 2011, 13:09:56 »
Quote from: TheSoulhunter;333414
Elecom M-DWUR
(Attachment Link) 17426[/ATTACH]
Major props to those guys for coming up with a thumbscroll that makes ergonomic sense.
A4Tech Opto325
(Attachment Link) 17425[/ATTACH]
Now that, I'm afraid, is not how it works...
Offline whizz
« Reply #15 on: Mon, 09 May 2011, 04:24:38 »
Hmmm it seems that the MX revolution is discontinued, only a very few shops have it.
I have found this http://steelseries.com/products/games/world-of-warcraft/world-of-warcraft-mmo-gaming-mouse. The thumb-buttons looks cool, but the overall design is horrible. Really don't need any LEDs on my mice. Also the steel surface will be probably uncomfortable.
Offline Brodie337
« Reply #16 on: Mon, 09 May 2011, 06:27:02 »
Logitech G700 might have enough buttons so you can work something out that fits your needs. I managed to pick one up cheap, and I'm really beginning to enjoy it. Its wireless, but you can use the included USB cable. Unlike mice like the Sidewinder X8, the USB cable is both data and power, so its a proper wired mouse if you need it to be.
Might be worth a look?
If you've got any questions about it, shoot me a PM.
Offline whizz
« Reply #17 on: Mon, 09 May 2011, 10:44:07 »
yeah, I am considering G700 too. How comfortable it is? I red that the side buttons are not much comfy.
Offline Brodie337
« Reply #18 on: Mon, 09 May 2011, 18:05:24 »
I was initially very skeptical of th side buttons, but I don't think theyre too bad. They're shaped in such a way that although they're nestled together, it's not too hard to hit the one you want. The triangular profile of the buttons help, and I think alot of the issues people were having came from how you press them. You don't press them straight down like a thumb button on say. the DeathAdder, I tend to sort of sweep them up with my thumb if that makes sense. Its easy enough to do given how they sit.
As for the top buttons, the top two under your left finger are almost shaped like a toggle, and I use them for DPI switching. They look like a pain, but the way they're shaped makes them easy enough to use. The only button I don't like is the one behind the free scroll button in the middle. It's just a bit awkwardly placed to my hands.
Offline whizz
« Reply #19 on: Tue, 10 May 2011, 05:23:51 »
OK, thank you, so I think I will try this mice. On my MX I also don't use that button behind the wheel, it's strange to use.
Offline Brodie337
« Reply #20 on: Tue, 10 May 2011, 09:17:52 »
Should mention the downsides to this thing. You only get a day or two out of the battery, and the charging cable is a stiff, heavy thing. Thankfully its MicroUSB, so I should be able to find a lighter replacement.
Only other thing is that some people dont like the coarse, hard finish on the sides. I personally do, but it's almost sandpapery. Very grippy though.
Offline The Solutor
« Reply #21 on: Tue, 10 May 2011, 09:28:35 »
Quote from: ripster;343830
Don't you guys have Best Buys in Canada?
Despite having a Logitech Nano Revolution now I wish I got one with a Unifying receiver.
buy an m705 then
Offline The Solutor
« Reply #22 on: Tue, 10 May 2011, 10:20:28 »
Quote from: ripster;344394
Too big for NotBook use.  Plus, kinda felt cheap in comparison.
When I bought it it was relatively expensive, don't remember if was 59 or 65 euro, now is likely the best mouse you can buy for 39$ or less.
Nano tracks better on some materials (some very dark cloth for example), but is really too small and lacks the middleclik.
Te older brother Revolution VX is slightly smaller but lacks the nano receiver, so is not an option here.
 you can look also at the razer orochi if you want a bacteria sized mouse being a bt mouse the receiver is not a problem.
Offline whizz
« Reply #23 on: Tue, 17 May 2011, 06:28:59 »
So I have bought that G700. Not a bad design, but I cannot live without that scrollwheel, it is so natural and comfortable! I am going find and buy world supplies of this mice. Do you have any idea where is in stock?
