Author Topic: help! broke my shift key stabilizer..  (Read 6229 times)
Offline nocturn4l3030
« on: Mon, 18 April 2011, 18:59:25 »
i just got my cherry red g80 board in the mail and i think i got way too overly excited when pulling out the keys to put on my double shots...
so when i pulled my left shift key i seemed to pop something out of place... i tried to put the shift key back on it but it's hard to push down.. i think i messed up something with the stabilizers
the stabilizers aren't attached to the key itself though.. it's jus for the board
i was able to get the left stabilizer "back in place".. but there's still something wrong.. like when i put the shift key on top it wont push down really or it's just kinda stuck there
i looked at the wiki real quick but i didn't see anything..
help on how to fix~!  here's my ghetto cell phone pic
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
Offline keyboardlover
« Reply #1 on: Mon, 18 April 2011, 19:02:03 »
No worries! See how on the left side the metal bar isn't clipped into place like on the right? Just try to push it gently back into the clip that holds it.
Nice board btw!
« Reply #2 on: Mon, 18 April 2011, 19:06:47 »
kbl~@! save meeeeeeeeeeee im like panicking haha
ok so yea it's like.. i was able to push it back into place but it doesn't feel right
it's hard to notice but the right stabilizer is higher than the left... i think i pulled the right stabilizer upwards.. like out of place or something.. it doesn't seem like i can push it back down though... should i use force? i dont want to break anyuthing further so i figured i'd post first =(
and thanks
[/strike]
[/SIZE]
« Reply #3 on: Mon, 18 April 2011, 19:09:22 »
when i put the bar back in place.. then i put the shift key back on it.. it pops back out..which i think is caused because i pulled the right stabilizer out a little bit.. as in "up"
[/strike]
[/SIZE]
« Reply #4 on: Mon, 18 April 2011, 19:09:56 »
Don't push it back down! You'll need to re-seat it. Don't worry; it's easy and you'll learn how it works.
Edit: lift up the right part of the stabilizer slightly. See how there's a little clip in the back? You need to put that part back into the pcb first, then push (slowly) the front part in as well (where the hole for it is).
Definitely don't force anything into any holes (that's what she said!)
« Last Edit: Mon, 18 April 2011, 19:13:32 by keyboardlover »
« Reply #5 on: Mon, 18 April 2011, 19:15:15 »
I ****in love you
thanks~!!!!!!!!!!!!!!!!!!!!!!!
[/strike]
[/SIZE]
« Reply #6 on: Mon, 18 April 2011, 19:18:13 »
Right back atcha!
We so excited.
« Reply #7 on: Mon, 18 April 2011, 19:19:53 »
you dont even know....i was like OMG $100+ down the drain asdlkfjdslfkjsldfkjsdlfkjsdlfkj
;D  time to plug this bad boy in
[/strike]
[/SIZE]
« Reply #8 on: Mon, 18 April 2011, 19:21:02 »
Yep, if you decide to put doubleshots on that board it'll likely happen again...but you'll get used to it and they really are easy to take out completely and re-seat. You only paid $100 for that board? Where'd you get it?
« Reply #9 on: Mon, 18 April 2011, 19:24:03 »
ahh yea you're right though..i actually took out the stabilizer and stared at it for a second jus to check out how it works..kinda.  now i wont be worried unless i actually break the stupid plastic thing
yeaa i got it from the classifieds section from "gregh" here on GH... was a cheap price because there's a cat scratch on the top of the board... but it's not as bad as i thought (the pictures magnified it) and it's definitely cheaper than the filco reds........annnnd i always wanted an authentic cherry board~!
i'm so excited...
over a keyboard >.<
LOL
[/strike]
[/SIZE]
« Reply #10 on: Mon, 18 April 2011, 19:24:38 »
Lol, I know what you mean =)
I ♥ My G80-3494's.
