Author Topic: XArmor U9 Cherry Brown - $80 from Amazon  (Read 1993 times)
Offline .XL
    • http://www.paokfc.gr/
« Reply #1 on: Tue, 19 April 2011, 13:16:43 »
Quote from: mojojj13;333503
http://www.amazon.com/XArmor-U9-Cherry-mechanical-keybord/dp/B004S86PBS/ref=sr_1_3?ie=UTF8&s=electronics&qid=1303235069&sr=8-3
Thoughts?
I believe this is the non-backlit version of the U9BLs. I'm not sure if anything else is different. It's a good deal for Browns; the only other sub-$100 option is the Das Keyboard with education discount.
Keyboards: Filco Majestouch-2 87key Browns - Realforce 103UB 55g - Compaq MX11800 (ghetto clears + doubleshots)
Offline Corland
« Reply #2 on: Tue, 19 April 2011, 15:39:54 »
Pretty sure this one is not an NKRO (it fails some 2kro from what I have heard) board like the U9BL-S, which is a pretty big difference for gamers
Offline .XL
« Reply #3 on: Tue, 19 April 2011, 17:05:16 »
Quote from: Corland;333601
If that's the case then this board isn't worth it. 6KRO is what you want in a gaming keyboard. NKRO is necessary only if your name is Dr. Octopus.
