Author Topic: Disable Alt Key  (Read 16721 times)
Offline marvkip
Disable Alt Key
« on: Tue, 19 April 2011, 23:30:19 »
Is there a way where I can disable the alt keys, or even just the left alt key in Windows 7? Just so i can use my mechanical keyboard while i wait for a response from EK.
Offline hcry4
  • HHKB Hoarder
Disable Alt Key
« Reply #1 on: Wed, 20 April 2011, 09:33:14 »
Autohotkey should solve this problem.
Offline alaricljs
  • I be WOT'ing all day...
Disable Alt Key
« Reply #2 on: Wed, 20 April 2011, 10:42:36 »
ahk:
Code: [Select]
#NoEnv
LAlt::
return
Filco w/ Imsto thick PBT
Offline marvkip
Disable Alt Key
« Reply #3 on: Wed, 20 April 2011, 11:05:49 »
Thank you guys SOOO much! :hail:
Offline alaricljs
Disable Alt Key
« Reply #4 on: Wed, 20 April 2011, 15:36:21 »
Hmmm, after a little thought you might want more than what that script does.  It will just prevent Left Alt from firing on it's own.  To make it so it can't fire on it's own or with any other key:
Code: [Select]
#NoEnv
*LAlt::
return
