Author Topic: Double Shots  (Read 3117 times)
Offline xenonrider
Double Shots
« on: Wed, 20 April 2011, 23:02:23 »
Why are Double Shot keys so revered?  Is it because of the way they're made or is it because it's just representative of a bygone era that was void of cheap mass production practices?
Offline audioave10
Double Shots
« Reply #1 on: Wed, 20 April 2011, 23:04:30 »
I think both of your answers are correct.
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline godofdeath
Double Shots
« Reply #2 on: Wed, 20 April 2011, 23:09:15 »
probably longer lasting unlike these filcos some people end up killing relatively quickly
Offline xenonrider
Double Shots
« Reply #3 on: Wed, 20 April 2011, 23:19:55 »
Quote from: godofdeath;334678
So they're more durable?  I've never seen keys shatter or break down during use.  Some intense and repetitive pressure must be being applied to these keys.
Offline jblack801
Double Shots
« Reply #4 on: Wed, 20 April 2011, 23:21:22 »
Isn't there a wiki that explains it? ;)
http://geekhack.org/showwiki.php?title=All+About+Keys
Offline nocturn4l3030
Double Shots
« Reply #5 on: Wed, 20 April 2011, 23:44:23 »
from personal experience... the default keys on most boards are thin/cheap abs keys.. when i put on my double shots.. they're thicker and shorter in profile which change the feel of the keyboard
and they look nice >.<
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
Offline NormaJean
Double Shots
« Reply #6 on: Wed, 20 April 2011, 23:46:51 »
When you hear that they are more durable, it's more about the labeling of the keys than the actual key falling apart.
There is no way that the letters are going to fade away on a doubleshot key
Offline MrSneis
Double Shots
« Reply #7 on: Thu, 21 April 2011, 01:27:54 »
But doubleshot keys can still shine after prolonged usage right?
Filco Tenkeyless Brown | Filco Tenkeyless-2 Blue | Leopold Tenkeyless Blue
Offline calavera
Double Shots
« Reply #8 on: Thu, 21 April 2011, 02:03:40 »
Quote from: MrSneis;334720
Yes. Double shots also have a very clear contrast which some people prefer.
Offline Oqsy
Double Shots
« Reply #9 on: Thu, 21 April 2011, 02:20:48 »
My cherry doubleshots are my shiniest and smoothest keycaps.
They will definitely go slick just like any others, but as mentioned above, the legends don't wear off.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline Ascaii
Double Shots
« Reply #10 on: Thu, 21 April 2011, 02:32:03 »
but then they are easy to unshine as well.
Ill sit watching a movie and gently rough up the top with some fine grade sandpaper + a drop of green dish soap, going through a set in about 20-30 minutes. Rinse them off after and the shine is gone.
(side note...by fine i mean FINE, you dont want crater-keys)
Double Shots
« Reply #11 on: Thu, 21 April 2011, 02:47:20 »
Quote from: Ascaii;334739
does that always work? ;O  after some point i'm sure if u keep doin that you'll jus mess it up?
[/strike]
[/SIZE]
Offline Pylon
Double Shots
« Reply #12 on: Thu, 21 April 2011, 08:26:04 »
1. They're high contrast and the lettering is extremely crisp.
2. The lettering is almost impossible to wear off.
3. Dye sub keys (the only decent alternative) are expensive/impossible to obtain for Cherry MX switches. You also can't get white lettering on black with dye sub.
