Author Topic: Will Win7 accept Win2000's keyboard drivers?  (Read 2096 times)
Offline BucklingSpring
« on: Fri, 22 April 2011, 11:19:59 »
The short story is in the subject.
I learned to type in French in the 80's when to do a >è< you had to hit >'< first, then >e<
same for >à<. But é was assigned to a single key >/<.
This French driver was carried over until Windows 2000. MS changed it in XP while keeping the same driver filename. Since XP >à<, >è< and few others are assigned to a single key.
I was able to overwrite XP's by 2000's and get the legacy layout to work properly.
My new work laptop will come with Windows 7 and I was wondering if I'm going to be able to import the same old keyboard drivers in it.
I'm no AutoHotkey programmer but I guess I'll have to learn how to convert a sequence of keys to produce a single one. Ie creating a "longcut".
Otherwise do you know a Windows 7 application able to make custom Keyboard drivers?
Thanks.
Boards I own, click ->
Offline IanS
« Reply #1 on: Fri, 22 April 2011, 12:12:16 »
Do you know about the US-international keyboard layout? It sounds similar to what you're used to:
Code: [Select]
Press this key Then press this key Resulting character
'(APOSTROPHE) c, e, y, u, i, o, a ç, é, ý, ú, í, ó, á
`(ACCENT GRAVE) e, u, i, o, a è, ù, ì, ò, à
http://support.microsoft.com/kb/306560
« Reply #2 on: Fri, 22 April 2011, 12:28:09 »
Quote from: IanS;335563
Code: [Select]
Thank you, that's the spirit... But not what I'm looking for.
eg I need '(APOSTROPHE) e, resulting in è not é
and for that matter }c, resulting in ç
And since I type mostly in English, I don't use the French AZERTY layout. I type of standard US keyboards. It's also easyier for me because I have small hands and the wide LEFT-SHIFT is very good for me. The French AZERTY has a key between the LEFT-SHIFT and the Z which is very anoying.
Back to my question. Do Win7 (32bit) will accept a Win2000 legacy keyboard dll?
This quick and dirty work around worked for me like a charm.
I might as well go with the flow and relearn how to type differently. :(
Offline Culinia
« Reply #3 on: Fri, 22 April 2011, 12:48:57 »
Hi there. Have you tried the Microsoft Keyboard Layout Creator?
I would imagine you could just load up the US International layout and just replace it with the chars you said...
File - load exiting keyboard - US International - right-click on the apostrophe key - 'properties for vk_oem_7 in all shift states... then click advanced view then click on the ... thing on the right.
This will take you here which I think you want
« Last Edit: Fri, 22 April 2011, 12:59:25 by Culinia »
Offline The Solutor
« Reply #4 on: Fri, 22 April 2011, 12:55:56 »
Look here, i had a similar problem.
My keymap uses `, then e to get è and alt graph+e to get é.
http://geekhack.org/showwiki.php?title=The+Solutors+UK+like+ANSI+Keymap+easy+diacritical+with+the+ANSI+keyboards
« Reply #5 on: Fri, 22 April 2011, 14:02:04 »
@Culinia - Thanks that might be the way... Will it be compatible with the ALT-SHIFT shortcut to switch between keyboard layouts ie US<->French for that matter?
@The Solutor - Thanks as well, was this for Windows 7?
I'll get my Win7 Laptop Monday and will start experimenting with those options.
Offline The Solutor
« Reply #6 on: Fri, 22 April 2011, 18:44:15 »
It works for sure on win 7, win vista, win xp, x86, x64 or ia64, likely also win 2k is supported.
Offline False_Dmitry_II
« Reply #7 on: Fri, 22 April 2011, 22:07:58 »
I'd say to go ahead and try your old solution first. Then if it doesn't work, do the other stuff. Make a backup of the win7 original files.
