Author Topic: Drobo anyone?  (Read 2866 times)
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
Drobo anyone?
« on: Sun, 24 April 2011, 12:48:46 »
Anyone  use Drobo?  I'm considering a lighter, greener, quieter solution to FreeNAS  (not that I don't love FreeNAS, I DO!).  Wondering if it uses it's own  proprietary file system or if it is a file system I could mount in a  linux box because, what if the Drobo fails on me?
Would I have any  options other than buying another drobo?
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Offline Brummell
Drobo anyone?
« Reply #1 on: Sun, 24 April 2011, 18:24:21 »
Have you looked at Synology?  I'm pretty sure they're ext3, and they're really sweet on a bunch of other levels.  I have one mounted as an iSCSI target and dump VMWare backups to it from Veeam.
Unicomp Space Saver | Filco Majestouch Blue | IBM Model M | Filco Majestouch Brown | Realforce 86UB | Leopold Blue | HHKB Pro 2
Offline phillip
Drobo anyone?
« Reply #2 on: Sun, 24 April 2011, 23:13:58 »
it does use its own system
i'd build/buy a windows home server box or look at using amahi home server or unraid
Offline dracaXL
    • http://www.technickal.org
Drobo anyone?
« Reply #3 on: Mon, 25 April 2011, 14:49:21 »
Ars Technica did a great and thorough review of the Drobo (although the comments are perhaps more revealing than the article!) - having read it, I'd go for the Synology unit myself.
Filco Majestouch Linear (i.e. MX Blacks) | Noppoo Choc Mini (MX Browns) | TVS Gold Bharat (MX Blue) | VorTex KBC Poker* (MX Red)
Intel Core i7-2600k | Gainward GTX 580 GOOD | 8GB XMS3 DDR3 RAM | Gigabyte P67-UD4 | Asus Xonar Essence ST | NZXT Phantom | KRK RP5 G2 w. Wharfedale SW150
*pre-ordered
