Author Topic: IBM M2 black, it exist ?  (Read 1389 times)
Offline The Solutor
« on: Mon, 25 April 2011, 11:37:20 »
As on the title IBM has ever produced a Black, or at least a non beige, IBM M2 ?
Offline Mr. Perfect
« Reply #1 on: Mon, 25 April 2011, 12:14:16 »
I have no idea. You could RIT dye a beige one though, if it doesn't have to be authentic.
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline The Solutor
« Reply #2 on: Mon, 25 April 2011, 12:18:41 »
I know i can paint/dye it. (I usually use the spray paint meant to paint the car's bumpers), but was just a curiosity, as I've never had a beige IT equipment in almost 30 years, and at the time avoiding beige was very difficult.
« Last Edit: Mon, 25 April 2011, 14:03:51 by The Solutor »
Offline ch_123
« Reply #3 on: Mon, 25 April 2011, 14:02:19 »
No.
Offline The Solutor
« Reply #4 on: Mon, 25 April 2011, 18:00:01 »
Danke
