Author Topic: help identifying compaq keyboard  (Read 2268 times)
Offline DigiSenzei
« on: Mon, 25 April 2011, 13:58:50 »
Hey guys been just reading the boards for a while now but today at salvation army low and behold a beautiful condition Compaq keyboard that looks like it has white alps i posted some pics up and if any1 can tell me anything about this model would be much appricated thanks much
[ Attachment Invalid Or Does Not Exist ] 17642[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 17643[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 17644[/ATTACH]
Offline Ascaii
« Reply #1 on: Mon, 25 April 2011, 14:02:44 »
Sure those are alps? How is the actuation and click? White alps are very clicky. If it doesnt klick you most likely have a hammer over dome board. The peg looks way too square imo anyways.
Offline DigiSenzei
« Reply #2 on: Mon, 25 April 2011, 14:05:13 »
not as clicky as my buckling spring still pretty loud in comparison to my gf rubber dome or my scissor switches
« Reply #3 on: Mon, 25 April 2011, 14:16:35 »
Plunger over rubber dome. Most rubber dome keyboards have the plunger as part of the key cap, but it is not uncommon that the plunger is a separate piece of plastic. Some plungers and key caps are ALPS-compatible, even.
Offline DigiSenzei
« Reply #4 on: Mon, 25 April 2011, 14:23:05 »
o well for 2 bucks it was worth a shot lol
Offline False_Dmitry_II
« Reply #5 on: Tue, 26 April 2011, 02:36:16 »
Honestly, it looked far too square for that. But its possible that its better than other rubber domes you've used before, so as long as its working it might be worth a try.
@Findecanor
You sith motha trucka
