Author Topic: Capture cards for Charity  (Read 3388 times)
Offline ZidaneTribal
« on: Mon, 25 April 2011, 14:07:08 »
For the past couple of years I have been working with a charity gaming marathon group (I am unsure about putting the name here since it may count as solicitation, but if I find out it is ok later I shall provide a link) to help raise money for a number of charities. A new run is coming up in June and I finally have a computer capable of handling a stream from my gamecube, PS2, or hopefully even my PS3 should I need to run it later. The only problem is that along with my Dell XPS 1330 I have been primarily running these marathons using a Sabernet AVCPT capture device. Sufficed to say it has been difficult, to the point that my last run of Windwaker made me physically ill at the 8 hour mark and I had to stop.
So now to accompany my new computer, I would like to look into a new capture card that won't cause me so much headache (or nausia).
I am currenlty running a http://www.asus.com/Motherboards/AMD_AM3/M4A89GTD_PROUSB3/ with a geforce installed, so sadly PCI avalabiltiy is a slight issue. I would prefer an internal device, but a better USB device will do in a pinch.
Proudly Suffers from "Chronic Hero Syndrome"
Offline Arc'xer
« Reply #1 on: Mon, 25 April 2011, 16:27:20 »
Not sure what your budget is but I seem to run into a lot of console gamer posts suggesting the blackmagic or hauppage capture cards.
But again there's a ****load of other capture card/software around so it becomes a matter of reading reviews and finding the one you want or should I say need.
« Reply #2 on: Mon, 25 April 2011, 18:15:51 »
Ahhh the good ol' days. I don't think people will want to sit and watch shakeycam gaming for 8 hours straight though. Thinking the AVErTV would work, mainly cause, well it fits. A bit higher than I want to pay, but if it helps draw people in long-term (and keeps me from puking on my monitor) might be worth it.
I considered the Hauppage but everywhere I looked the reviews were pretty poor till about the 100 dollar mark anyways
« Reply #3 on: Mon, 25 April 2011, 18:31:25 »
Ohhhhh, no. I was talkin about back when you had to actually point the camera at the TV and get a really bad grainy shakeycam recording on a VHS...
I feel old now.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #4 on: Mon, 25 April 2011, 23:20:44 »
You might consider a pure analogue card, like the old cards with the BT878 chipset.  It does no pre-processing to ease conversion to MPEG, so there's frequently no delay (with the right software).  A lot of fancier cards will attempt to process the video down, and then you get lag on screen.  Playing PS2 games with a three-second lag doesn't work.
Overton130, Box Pale Blues.
Offline HaveANiceDay
« Reply #5 on: Tue, 26 April 2011, 14:34:55 »
What you want is the Blackmagic Intensity. Available as internal or external(usb3).
You get up to 1080i capture. 1080p is not possible because of HDCP.
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
