Author Topic: Xarmor and keycaps  (Read 2174 times)
Offline Zamorph
Xarmor and keycaps
« on: Mon, 25 April 2011, 14:29:41 »
Does Xarmor use special sized keycaps? Their spacebar looks a little bigger.  Jw, cuz I may replace the keycaps on a U9 plus
Offline ricercar
  • mostly abides
Xarmor and keycaps
« Reply #1 on: Mon, 25 April 2011, 16:59:16 »
Quote from: Zamorph;337066
Spacebar on original U9BL is actually not as wide as a spacebar from common Cherry boards such as the 11900 (see pic).
PS
Picture attachments appear to defaul to viewable inline since the forum upgrade. Is this a preference setting? Older posts thus end up displaying the same pic twice.
Offline The Solutor
Xarmor and keycaps
« Reply #2 on: Mon, 25 April 2011, 17:28:22 »
Quote from: ripster;337142
Them some big sprues.  Weird spacebar.
Yeah, mine looks more normal
Offline ricercar
  • mostly abides
Xarmor and keycaps
« Reply #3 on: Mon, 25 April 2011, 17:31:35 »
That spacebar with sprues is from a MY keyboard; lots of MY boards have sprues on keys wider than 1x1.
However, it's the same width as the MX spacebar on my G80-11900 series.
