Author Topic: Larger Alt key?  (Read 1394 times)
Offline MrPhil
Larger Alt key?
« on: Mon, 25 April 2011, 16:30:12 »
Hey guys
Just got my new filco cherry brown keyboard for work and i noticed a subtle difference than the piece of crap keyboard work supplied. The alt keys are closer to the centre which for most people is hardly a problem but in my field my thumb is constantly on the alt key. I'm sure i'll get used to it but just wondering if there are any alternate keycaps i can buy to help?
It seems like looking at both keyboards the control keys are smaller on the filco which makes for a larger space bar.
-Phil
Offline dusii
Larger Alt key?
« Reply #1 on: Mon, 25 April 2011, 18:31:12 »
Depending on where you work, mapping windows to alt could be a option.
Offline MrPhil
Larger Alt key?
« Reply #2 on: Mon, 25 April 2011, 18:35:32 »
Thanks dusii! But that won't solve my problem and i don't think i was very clear in my post. Really should post up some pics but don't have the means to right now.
It's more that i want to move the left alt key to the right a little more. Probably means the layout is a little different to what i'm used to
