Author Topic: Need to buy 1 Cherry MX Blue Switch  (Read 2435 times)
Offline litster
  • rare caps?! THAT'S A SMILIN
« on: Thu, 28 April 2011, 22:25:08 »
Does anyone know where I can buy 1 Cherry MX Blue switch?  While changing key caps, my superman stength made me pull out the entire switch.  I am in the process of soldering it back.  If it doesn't work, I will need to buy a new one :(
Thanks.
Offline godofdeath
« Reply #1 on: Thu, 28 April 2011, 22:25:55 »
there was some american site but i cant remember
it costs like a buck for it
Offline wanabe
« Reply #2 on: Thu, 28 April 2011, 22:41:21 »
check mouser or digikey
« Last Edit: Thu, 28 April 2011, 22:45:01 by wanabe »
Offline RickyJ
« Reply #3 on: Thu, 28 April 2011, 22:43:57 »
Or just swap it with something useless like Scroll Lock.  Watch for torn PCB traces!
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline litster
« Reply #4 on: Thu, 28 April 2011, 23:49:04 »
Thanks for the help, guys.  I was able to solder it back on to the curcuit board.  That freaked me out.  For some reason, the puller caught the edges of the switch and let me pull the whole thing out.  This is an old Das Keyboard II, a Cherry made board.  Thanks.
Offline litster
« Reply #5 on: Fri, 29 April 2011, 01:24:49 »
Yep, that is exactly how the puller was holding the switch when th puller was 3 feet away from the keyboard!  LOL!  I learned something new.
