Author Topic: Solved  (Read 1705 times)
Offline Human
Solved
« on: Fri, 29 April 2011, 05:22:51 »
Solved
« Last Edit: Fri, 29 April 2011, 05:25:42 by Human »
Offline alaricljs
  • I be WOT'ing all day...
Solved
« Reply #1 on: Fri, 29 April 2011, 08:46:03 »
Can I just point out that it's really annoying for people to make a post and then later obliterate what they posted about to replace it with something useless like 'I don't have this issue any more'
What issue?  Maybe someone else is (or will in the future) having the same issue and would benefit from your solution?  It would have been much nicer if you just replied to your post with the solution to your problem.
Filco w/ Imsto thick PBT
Offline HaveANiceDay
Solved
« Reply #2 on: Fri, 29 April 2011, 08:48:36 »
Quote from: alaricljs;339115
I kinda had the same thought. The forums are not throwaway one-time-view-then-burn notes.
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
Offline bionicroach
Solved
« Reply #3 on: Fri, 29 April 2011, 16:34:13 »
