Author Topic: TIPRO question  (Read 1696 times)
Offline krstf
TIPRO question
« on: Fri, 29 April 2011, 09:35:55 »
Hello
I was wondering if it is possible to program TIPRO keyboards under Mac OS? I've been looking at their website but the Change Me software is Windows only it seems.
Alternatively: Could one program one of these using Windows and just use it on a Mac afterwards / would Mac OS recognize the layout?
Thanks in advance.
Offline kbdfr
TIPRO question
« Reply #1 on: Fri, 29 April 2011, 10:31:40 »
You can program keyboards in any Windows system (98, NT, 2000, ME,
XP), but you can use them also in other systems (Unix, Linux, OS/2, Mac
OS...) that support IBM standard keyboards.
That's what the ChangeMe User's Guide says (FAQ section, page 159).
Offline krstf
TIPRO question
« Reply #2 on: Sat, 30 April 2011, 06:53:00 »
Allright, thanks!
Off to find a Windows machine with native PS/2 port...
