Author Topic: How hard is it to dye sub stuff?  (Read 1643 times)
Offline Pylon
« on: Fri, 29 April 2011, 13:54:44 »
With the prices Cherry dye sub caps have been going for and the insane rates SP charge for dye sub keys, I've been thinking about someone here buying a dye sub machine and some blank caps from Cherry, KBC, or SP and making their own dye sub caps.
Or maybe buy some PBT caps and ask Key-tech to do it.
Is it viable?
Offline keyboardlover
« Reply #1 on: Fri, 29 April 2011, 14:24:07 »
I'm waiting for the Kbc dyesubs. Prbly would get them before group three ships.
Offline Mazora
« Reply #2 on: Fri, 29 April 2011, 14:36:58 »
KL: was that part of the group buy ? I dont see any dye sub in the list. Is it too late to order some?
HHKB Pro 2: black case white keys
Filco Masjestouch v2 / MX-Reds / hard lending pads /Dye-sub keycaps
RF-87UW
Offline digitalleftovers
« Reply #3 on: Fri, 29 April 2011, 14:45:24 »
My company works with dye-sub photo printers.  Assuming that it is a similar process, dye sublimation is an extremely expensive printing process.  there are three basic components:
- Thermal print head
- Dye sub ink (three or more colors of ink on a plastic sheet.
- dye receptive media: Paper or in this case keys.
Thermal head heats up and produces the pattern of the image against the dye film, against the receptive media.  It has to make multiple passes against the media (one for each color).  Color doesn't really apply for the keys, but I don't know how many passes it takes for the letters to be the desired bright-white.
Reasons that it is expensive: the dye film is not reusable, and a lot of it is wasted (not transfered to the media) and the thermal heads have a short life span.  In the photo industry, the heads cost several hundred dollars and are only good for about ~70,000 prints.  The dye film is not cheap either, and often comes on proprietary rolls (each has a special RFID code).
I would be curious to know how the key thermal printers work, but I'm guessing based on my experiences, laser printed keys are probably cheaper.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
« Reply #4 on: Fri, 29 April 2011, 15:26:55 »
Quote from: Mazora;339252
No.
