Author Topic: USB ports on keyboards  (Read 1742 times)
Offline Zamorph
« on: Mon, 02 May 2011, 14:26:33 »
Do the usb ports on keyboards have any problems?  Some keyboards sport usb 2.0, do they have any input lag?  Thanks :)
Offline Arc'xer
« Reply #1 on: Mon, 02 May 2011, 14:33:26 »
Input lag comes from many other sources and many other components; than the ports themselves.
Offline Zamorph
« Reply #2 on: Mon, 02 May 2011, 14:36:17 »
Ah gotchya, if I used double usb ports, I would probably have my Headset and either a mouse/ipod in the second one, think it could handle it?
Offline pitashen
« Reply #3 on: Mon, 02 May 2011, 14:46:17 »
There won't be lag, but it would definitely affect the bandwidth. I did witness reduce in pulling rate when my mouse is plug into a hub sharing bandwidth with other device. No biggy though, for the most part.
Offline Zamorph
« Reply #4 on: Mon, 02 May 2011, 14:46:57 »
Quote from: pitashen;340512
Ahhh I thought that would happen.
Offline The Solutor
« Reply #5 on: Mon, 02 May 2011, 14:49:31 »
Quote from: Zamorph;340505
I actually have a mouse receiver and a Droid Z (tmobile G2 in the US) connected to my backlit keyboard, w/o any problem.
That said it depends on the mainboard and its age.
Offline Zamorph
« Reply #6 on: Mon, 02 May 2011, 15:10:41 »
Quote from: ripster;340531
Lulz.  Wrong again.  Especially unforgivable after trolling the "My IBM doesn't work on PS/2" thread.
USB is a regulated 5.0V and amperage.  Only real exception is laptops.  They suck at following specifications.
Is it 5 per USB? I just looked up my head set and it needs 3.0 V, 2.2 K ohm
Offline The Solutor
« Reply #7 on: Mon, 02 May 2011, 15:11:31 »
Lulz.  Wrong again.
You should read "The Fox and the Grapes" you can learn a lot about yourself.
You should also try to speak about something you tried.
Unlike you, most of the modern motherboards are vastly tolerant about the current they provide trough USB, sometimes you can drain even 2 A (which is 4x what the specs recommends).
