Author Topic: Keyboard Macro Helper for 101 key keyboard  (Read 3142 times)
Offline Ham
« on: Mon, 02 May 2011, 16:14:01 »
Hello, this is my first post. :wave:
I have tried to write some macros in autohotkey, spent 2 evenings with no result.
This led me to write useful program in Delphi. This program maps buttons near home row
 for right hand to Ins, Del, Up, Down, Left, Right that can be used with Shift,Ctrl buttons that are mapped for left hand. So you can minimize hand movements.
I also wrote this app. that it can be used with 101 key keyboard. So right Alt is mapped to Win key. I use arrow keys with Ctrl Shift and combinations very often while programming. Aslo this app. can be useful to those who have tenkeyless keyboard.
http://depositfiles.com/files/2yjh71ogw
Detailed description of the program is in archive. Executable file is in "Proj72\Debug\Win32" directory.
If you have found bugs report me with detailed description. Program is open-source.
« Last Edit: Mon, 02 May 2011, 16:38:47 by Ham »
Filco Majestouch 105 key NKRO blank MX Blue; unknown TPC mechanical 101 key; Razer Tarantula.
