Author Topic: G84-4100 PS/2 to USB?  (Read 2011 times)
woody
  •  Guest
« on: Wed, 04 May 2011, 11:23:46 »
Has anyone tried plugging a G84-4100xPxxx via a passive PS/2 to USB adapter? I've read it should support it, but I lack this kind of adapter and cannot try. Or it could be a misinformation.
EDIT: Solved. The xPxxx most likely don't support this. The xCxxx models do.
« Last Edit: Wed, 04 May 2011, 11:44:18 by woody »
woody
  •  Guest
« Reply #1 on: Wed, 04 May 2011, 11:43:02 »
Unicomp was never advertised as a dualie, AFAIR.
Ok, I found where I read about the G84-4100. And the mystery is solved, thanks to The Keyboard Company!
It's the xCxxx model (the combo PS/2+USB) that support this. They, like the other dualies, sport USB connector and include USB-to-PS/2 passive adapter.
The xPxxx models are PS/2 only. They need active converter.
Links:
xCxxx
xPxxx
Thanks, Ripster. You were helpful in an unexpected way.
woody
  •  Guest
« Reply #2 on: Wed, 04 May 2011, 12:18:57 »
In the white rounded thingy in the lower right, by default or if you pass the cursor over the "Connection: Combi USB & PS/2" field.
Cherry info also hints in this direction.
Don't know about the color, though. I have purple and green passive USB-to-PS/2 dongles.
