Author Topic: Aibo Alps Mechanical Keyboard.  (Read 4984 times)
Offline digitalleftovers
« on: Thu, 05 May 2011, 18:18:46 »
An inexpensive, plate mounted alps board that claims
- Tactile feeback
- USB
- Laserd Keys
- Less than $70 shipped.
- Strangely compressed layout
Found it on PCHome: link here
I have not seen it on geekhack before, and ALPS doesn't get a lot of attention anymore, so I thought it was worth a post.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline Pylon
« Reply #1 on: Thu, 05 May 2011, 19:55:44 »
For a US user a DSI 6600 might be a better deal, though it has a small backspace.
Offline The Solutor
« Reply #2 on: Thu, 05 May 2011, 20:12:27 »
I asked the same question yesterday and I had no reply,  looks like a good deal for everyone want to try an alps board, but is just a guess.
« Last Edit: Thu, 05 May 2011, 20:36:10 by The Solutor »
Offline Mr. Perfect
« Reply #3 on: Thu, 05 May 2011, 20:23:29 »
They murdered that layout though. :moony:
What happened to all the Alps boards, anyhow? Filco Zeros and whatnot.
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline The Solutor
« Reply #4 on: Thu, 05 May 2011, 20:34:25 »
Layout looks almost perfect to me, way better than the standard ansi.
Offline MKB
« Reply #5 on: Fri, 06 May 2011, 02:15:19 »
SIIG makes a white alps board and if you have a Fry's nearby they often have one out...  Not the highest quality board but gives a good impression of the keys....
I have the Filco Zero and want a second one...
________________________________
Current:
Leopold Tenkeyless (Cherry Clears)
Leopold Tenkeyless (Cherry Reds)
Filco Tenkeyless Zero (White Fukkas)
Unicomp SpaceSaver 104 (Buckling Spring)
Past:
IBM Model F (Buckling Spring)
IBM Model M (Buckling Spring)
Northgate (White Alps)
Fujitsu (peerless)
HHKB Pro 2 (Topre)
Deck Legend (Cherry Blacks)
Deck 82 (Cherry Blacks)
Unicomp Customizer 104 (Buckling Spring)
« Reply #6 on: Fri, 06 May 2011, 12:27:24 »
This is the DSI that I know of, the BF-I-113.  Amazon has them on sale sometimes.  Plus its got BIG FONT, and ALPS.
Keyboards:
Offline Pylon
« Reply #7 on: Fri, 06 May 2011, 14:27:17 »
I was talking about this DSI
It goes under a few other names (SolidTek, etc.)
Offline Mr. Perfect
« Reply #8 on: Fri, 06 May 2011, 14:39:56 »
Man, I was about to say that was a nice price, but it's back ordered.
Do all of DSI's boards use the BIGass enter key? I just finally replaced a board that had one of those ridiculous keys.
« Reply #9 on: Fri, 06 May 2011, 15:48:05 »
Quote from: Mr. Perfect;342620
They were that low price and still available at one time(a few months ago).  My guess is that the price will go back up as soon as they come back in stock.  Other stores have them, but for much more money.
Keyboards:
Offline The Solutor
« Reply #10 on: Fri, 06 May 2011, 16:14:35 »
Aibo has a good enter w/o the sacrifice of backspace, unlike DSI.
Offline Pylon
« Reply #11 on: Fri, 06 May 2011, 20:40:12 »
The DSI is a lot cheaper, though both the DSI and the Aibo are cheaper than the Matias Tactile Pro 3, which has a proper ANSI layout. Ideally, you could buy the DSI and a used Dell AT101W, swap leaves and springs to get what are essentially ghetto complicated white Alps on the Dell and ghetto simplified blacks on the DSI, and thus get a proper ANSI Alps board with complicated whites (which are considered better than simplifieds). The overall price would be similar to the Aibo, but you get two boards instead of one and a non-funky layout.
(remember to swap springs if you do this since black Alps use heavier springs than white Alps)
Offline ch_123
« Reply #12 on: Sat, 07 May 2011, 02:52:47 »
The evils of small backspaces are over rated. Never had issues with them.
« Reply #13 on: Mon, 09 May 2011, 17:21:55 »
carrying on with these inexpensive asian alps boards... I just noticed this over on Deskthority.  It is available on taobao, made by a company called ARON.  As you can see, they have green alps (and apparently white, as well).  There are standard and ergo versions.  It was posted by Julie:
Sold here: http://item.taobao.com/item.htm?id=8681349198
KB-AU106
109Pro
Keyboards:
Offline Hak Foo
  • Make America Clicky Again!
« Reply #14 on: Tue, 10 May 2011, 00:58:24 »
o.o
o.O
O.O
Possible Whites?  Under 200 RMB?  KR lettering?  Sensible enter?
Curses.  I've got to bother the Chinese guys I work with to find out more.
Overton130, Box Pale Blues.
Offline False_Dmitry_II
« Reply #15 on: Tue, 10 May 2011, 01:54:12 »
Hrm, you can solder complicated switches into the spot simplifieds used to be right?
