Author Topic: Trying to Update My Northgate OmniKey 102  (Read 2211 times)
Offline DigitalDawn
« on: Fri, 06 May 2011, 15:29:47 »
Hi,
I've been reading through some of the threads here and it's nice to see other Northgate Keyboard owners.
I have an OmniKey 102 and I want to update it a bit.
1. Would like to re-paint the plastic taupe-colored cover which has yellowed a bit over time. Has anyone ever done this? If yes, what type of paint did you use, and what steps did you take?  It's really easy to remove the cover by unscrewing the screws on the back of the keyboard.
2.  All the alps switches seem to be in good shape, but I would like to replace all the keycaps. An ideal color for me would be a brighter white background with black or grey characters. I'm not a real fan of the cream colored keycaps I have now. Anyone know where I could get new keycaps at a reasonable price?
Offline 8_INCH_FLOPPY
« Reply #1 on: Fri, 06 May 2011, 16:25:29 »
Northgates are some of the few alps keyboards that have doubleshot keys. You'll probably want to keep the ones you have.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
Offline False_Dmitry_II
« Reply #2 on: Fri, 06 May 2011, 16:33:44 »
In the modifications fourm there's a guy who sands down his blackwidow, then spraypaints it with white paint, then takes it to an auto body shop for a final coat. I bet you could do the same thing.
Most sets of buys for keycaps are for cherry boards. I don't know how much a set of alps would be. There is this place, though:
http://keycapsdirect.com/
Offline nraymond
« Reply #3 on: Fri, 06 May 2011, 17:47:22 »
Quote from: DigitalDawn;342647
You can undo the yellowing.  See this:
http://www.vintagecomputing.com/index.php/archives/189
and this:
http://retr0bright.wikispaces.com/
Offline DigitalDawn
« Reply #4 on: Fri, 06 May 2011, 18:09:03 »
Quote from: False_Dmitry_II;342672
Been there. They want $800 for a complete set of key caps.
