Author Topic: slight scratches on PBT keycaps, anyway to remove them?  (Read 13712 times)
Offline nocturn4l3030
« on: Fri, 06 May 2011, 18:43:56 »
just put imsto's PBT keycaps on my filco and even though you can only see them in the light.. i can see two long scratches on the spacebar.. i even did a fingernail scratch test on it and now there's 3 =(  lol
i'm pretty surprised how easy it was to scratch it with my fingernail...
is there any way i can remove these? it's very slight but it's enough to bug me.. considering i paid so much for these keycaps too
« Last Edit: Fri, 06 May 2011, 18:46:06 by nocturn4l3030 »
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
Offline panda-R
« Reply #1 on: Fri, 06 May 2011, 18:47:52 »
you can sand it smooth but then u'll have to do the entire keycaps to match.
DO YOU FEEL THE BEAT? I DO.
One Keyboard to DOOM them all, REALFORCE.
« Reply #2 on: Fri, 06 May 2011, 18:53:23 »
=(  how annoying
[/strike]
[/SIZE]
Offline panda-R
« Reply #3 on: Fri, 06 May 2011, 18:53:46 »
sorry bro but the the laws of physics must be obeyed!
Offline MrSneis
« Reply #4 on: Fri, 06 May 2011, 19:02:54 »
Maybe you can rub it a bumch?  But then you'd wear down the keycap so it's closer to getting shiny.
Filco Tenkeyless Brown | Filco Tenkeyless-2 Blue | Leopold Tenkeyless Blue
« Reply #5 on: Fri, 06 May 2011, 19:03:42 »
you guys are supposed to make me happier
but now i'm sadder
rofl ****kkkkk
[/strike]
[/SIZE]
Offline panda-R
« Reply #6 on: Fri, 06 May 2011, 19:23:58 »
No time to worry about Entropy and the Death of the Universe, boobs moar important.
and relax dude, they're just keycaps. They don't make u feel good in the bed.
Offline The Solutor
« Reply #7 on: Fri, 06 May 2011, 20:15:07 »
Quote from: nocturn4l3030;342732
I think you can use the good old toothpaste (no gel, fluor, whatever, just a good old white one), I never tried it on a keycap, but is a trick widely used to get rid of scratches on chellpone's, plastic displays and housings.
Offline BucklingSpring
« Reply #8 on: Fri, 06 May 2011, 20:23:52 »
Quote from: ripster;342797
Those are all shiny surfaces, not matte.
LoL too bad the OP didn't say he had a DAS. :-)
Boards I own, click ->
Offline pitashen
« Reply #9 on: Fri, 06 May 2011, 22:07:05 »
Mr. OP, don't worry, your finger will polish off the scratch in no time :)
Offline kaiserreich
  • HHKB Elite
« Reply #10 on: Fri, 06 May 2011, 23:50:12 »
I was told that rubbing it (?) with an eraser can help, thou that's on ABS. Maybe you can try it for your PBT caps too
« Reply #11 on: Sat, 07 May 2011, 06:13:26 »
Quote from: pitashen;342841
LOL.. i guess that's my only choice now =[
[/strike]
[/SIZE]
« Reply #12 on: Sat, 07 May 2011, 06:14:09 »
Quote from: kaiserreich;342873
ah jus tried that with a pink eraser.. no go =( it did remove my fingernail scratch as i guess it wasn't that deep.. but didn't do anything for the other one.
used the old fashioned pink eraser.
thanks for the suggestion though!
[/strike]
[/SIZE]
Offline Engine
« Reply #13 on: Sat, 07 May 2011, 10:05:28 »
I keyboard that gets used will look used.  I think you should remember what Ripster said.  Now you won't mind the shiny space bar effect in 6 months.  OCD only robs joy.  I know a little about this.  Just use it and enjoy.  Your keyboard now is "unique".  One of it's kind.....Oh, a "limited edition". =)
I'm still playing with my new keyboards and don't have these problems yet but may wish to do something about it when it happens, I don't know but I'm determined to be content just in case there's no easy fix.  That's my advice anyway.
@Ripster,
What's IMSTO?
« Last Edit: Sat, 07 May 2011, 10:14:35 by Engine »
In order of purchase:
Unicomp Space Saver(Black) - Topre Realforce 103U-UW -   Topre Realforce 103UB - Leopold Tenkeyless MX Blue - Leopold Tenkeyless MX Brown - Filco Majestouch 2 MX Blue - Filco Majestouch 2 MX Brown
Offline NimbleRabit
« Reply #14 on: Sat, 07 May 2011, 10:17:19 »
Imsto is the name of the person selling these keycaps.  This is the thread:
http://geekhack.org/showthread.php?16260-PBT-104-keycaps
Offline Engine
« Reply #15 on: Sat, 07 May 2011, 11:36:16 »
Thanks.
