Author Topic: + key died on filco, need fix  (Read 2331 times)
Offline godofdeath
« on: Fri, 06 May 2011, 23:43:58 »
The + key on the number pad seems to have died on me??
Is there anyway to fix this?
Offline kaiserreich
  • HHKB Elite
« Reply #1 on: Fri, 06 May 2011, 23:48:36 »
Open the case up, set the multimeter to check for short circuit. Point the leads to the 2 ends and press the switch. If there's anything that changes on the readings, that means the switch is fine, and I can't think of another way to diagnose.
If there are no changes/sound from the multimeter, change the switch and you will be good to go.
Offline godofdeath
« Reply #2 on: Fri, 06 May 2011, 23:51:56 »
well it works a bit
i hold it for like forever on excel and a plus will pop up
hmmmmmm
Offline godofdeath
« Reply #3 on: Sat, 07 May 2011, 00:00:47 »
Quote from: harrison;342875
sounds like either the contacts are faulty, or the solder joint has broken
so i still needa pop it open?
Offline kaiserreich
  • HHKB Elite
« Reply #4 on: Sat, 07 May 2011, 00:05:43 »
Or use a hot air gun and peel the sticker off and stick it back.
Offline godofdeath
« Reply #5 on: Sat, 07 May 2011, 00:11:02 »
Quote from: harrison;342879
that's where i'd start.  you'll void whatever warranty you've got left though.
ebay board off armygroup if i remember correctly so yea... lol
« Reply #6 on: Sat, 07 May 2011, 00:44:02 »
Quote from: godofdeath;342869
Well, here are your options: you can sell it for parts, throw it off a cliff… you can donate it to a person that you’d like to see die in a keyboard crash, or, you can sell it to me, and I’ll use it as I would a hammer on my farm.
my offer is 15$+ shipping.
/// Current
Leopold 87 White MX | Filco 104 Brown | BlackWidow | WhiteWidow  |  TG3 Deck | 2x NIB  Dell AT101W | NIB  Dell QuietKey | IBM 3278 | Logitech NetPlay | Logitech G15 v2 | Saitek Eclipse v1 | Apple A1314 | Logitech K700
/// Past
HHKB Pro 2 | Realforce 86UB
Offline elef
« Reply #7 on: Sat, 07 May 2011, 05:22:29 »
Quote from: kaiserreich;342880
If it's still under warranty, I'd just try to get it fixed/replaced under warranty.
If the warranty is up or you live 10,000 miles from the company that sold it to you and you don't want to pay a million dollars for shipping and wait for the rest of your life to get it back, then you don't have much to lose. Just open it up.
