Author Topic: Rackmounting the Compaq MX11800  (Read 1942 times)
Offline jayray999
« on: Thu, 12 May 2011, 10:17:49 »
I own a Compaq MX11800 that I absolutely love. Unfortunately it did not come with any mounting rails. Any ideas for a compatible sliding solution for a standard 19" server rack? I bought a generic drawer on *BAY but it proved to be just a tad too small. Anyone have a solution including if you own (but do not use) the original rails and would like to sell them to me. Thanks.
"In Italy for thirty years under the Borgias they had warfare, terror, murder, bloodshed and they produced Michelangelo, Leonardo da Vinci and the Renaissance. In Switzerland they had brotherly love, five hundred years of democracy and peace, and what did they produce? The cuckoo clock."
Harry Lime (Orson Welles) :: The Third Man (1949)
Offline The Solutor
« Reply #1 on: Thu, 12 May 2011, 10:24:55 »
Too small in what direction ?
Do you mean 1U tray is not enough ?
There are 2U trays like this, which is expensive, but I'm sure than something less expensive will be not too hard to find.
Offline jayray999
« Reply #2 on: Thu, 12 May 2011, 10:32:51 »
The keyboard is 16-1/4" wide x 7-1/2" deep while the cavity of the tray I got is 15-7/8" x 7-1/2" so the width is about 3/8" off and the depth is a close fit. The seller advertised the wrong dimensions.
Offline The Solutor
« Reply #3 on: Thu, 12 May 2011, 10:40:21 »
So this one should fit your requirements http://www.mountsandmore.com/asp/show_detail.asp?sku=DF1785
If the specs are correct, obviously.
Offline False_Dmitry_II
« Reply #4 on: Thu, 12 May 2011, 11:08:58 »
Well, I'd get my money back in that case. It isn't that it turns out to not be what you needed. It turned out that it was wrong to begin with.
Offline jayray999
« Reply #5 on: Thu, 12 May 2011, 12:47:42 »
Thanks guys. He somehow sent the outer dimensions. Anyway, I will either get the one Solutor suggests or perform keyboard surgery with a hacksaw and some silicone.
Offline Mr. Perfect
« Reply #6 on: Thu, 12 May 2011, 15:38:13 »
Rather then hack up the keyboard, could you hack up the tray? Maybe mount the keyboard straight to the rails and ditch the tray part?
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
