Author Topic: need translation of computer speak "PHP error" message  (Read 2218 times)
Offline Voixdelion
« on: Fri, 13 May 2011, 09:16:42 »
This is a new one for me and I just visited this page yesterday  - What exactly does this mean (and how do I fix it?):
A PHP Error was encountered
Severity: Warning
 Message: mysql_connect() [function.mysql-connect]: Host  's15449709.onlinehome-server.info' is blocked because of many connection errors;  unblock with 'mysqladmin flush-hosts'
 Filename: mysql/mysql_driver.php
 Line Number: 66
 A Database Error Occurred
 Unable to connect to your database server using the provided  settings
"The more you tolerate each other, the less enforcement will happen."-iMav
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #1 on: Fri, 13 May 2011, 14:39:25 »
That's typically not something you as a user can do much about, it's a server-side problem.
Apparently the web server cannot connect to the SQL database backend, and without that, it's lost. Sites relying on databases are very common these days. Need to keep user logins? Requires a database. Content management system? Requires a database. A forum or a blog? Probably needs two.
