Author Topic: AutoHotKey: Share your Scripts!  (Read 44544 times)
Offline alaricljs
  • I be WOT'ing all day...
« Reply #50 on: Sat, 07 January 2012, 17:40:07 »
For the functions you are saying do not work, all that is happening with the script is that it is taking your key press combination  and translating it to the related media key press that could be found on any keyboard claiming to have media keys.  It is up to iTunes to tell the OS that when media keys are pressed they should be forwarded on to iTunes.  I've never used iTunes so I have zero familiarity with it.  With Winamp it's a specific setting inside the Global Hotkeys screen.  On Windows XP there was a Control Panel that allowed you to fiddle with that stuff as well.  I have not found the same control panel in Win7.
Filco w/ Imsto thick PBT
Offline 1uckyNumb3r7
« Reply #51 on: Sun, 22 January 2012, 23:30:36 »
I have a question for the AHK vets on here....
I am running this line in a script because I am using a Model M and want to have a Windows key for some volume and media function scripts that need that key.
Code: [Select]
RControl::LWin
The key works like it is supposed to, so if I hit RControl+Up then the volume goes up.
My problem is that when I release the RControl after hitting Up then the start menu pops up and I have to hit RControl again in order to make it go away. Is there a way to make it act like a normal LWin key and not pop up on the release of RControl?
Offline slueth
« Reply #52 on: Sun, 22 January 2012, 23:34:37 »
i think you can get the windows key by hitting the shift and cntrl or some combo like that.
« Reply #53 on: Sun, 22 January 2012, 23:59:25 »
Quote from: slueth;496578
You might be thinking of Ctrl + Esc? It will bring up the start menu but that is it.
If I were to hit Ctrl+Esc+Up it wouldn't behave the same as Win+Up
Edit: I forgot to mention that if I plug in my other keyboard and try the Win+Up combo the volume goes up and the start menu doesn't pop up.
Edit 2: I found a solution, but it does not involve the use of AutoHotKey unfortunately. http://www.jonlee.ca/remap-capslock-the-most-useless-key/
How to remap Caps Lock to another key
For Linux users (on an X environment like KDE, Gnome), it’s pretty easy to remap keys using the xmodmap command.
For Windows users, there are programs that will remap keys for you but if you’re not afraid to tinker with your registry, you can do this manually and it only requires adding one registry value:
    Go to Start->Run and type in ‘regedit’ to open the registry editor.
    Navigate to:
        HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout
        Note: Keyboard Layout, not Keyboard Layouts!
    Go to Edit->New->Binary Value and name it ‘Scancode Map’
    Now double-click and edit the value to the following, replacing ## ## with the scan code of the key you wish to map caps lock to.
        00 00 00 00 00 00 00 00 02 00 00 00 ## ## 3a 00 00 00 00 00
    The scan code for Windows Key is 5B E0, Esc is 01 00, Ctrl is 1D 00. Full list of scan codes and a more detailed tutorial is here.
    Reboot your computer and say goodbye to caps lock!
« Last Edit: Mon, 23 January 2012, 09:34:02 by 1uckyNumb3r7 »
Offline Hamblet
« Reply #54 on: Mon, 23 January 2012, 00:30:20 »
Quote from: 1uckyNumb3r7;496577
...My problem is that when I release the RControl after hitting Up then the start menu pops up and I have to hit RControl again in order to make it go away. Is there a way to make it act like a normal LWin key and not pop up on the release of RControl?
Try this code, It works fine with me (I am AHK_Basic and Vista 32)
Hotkey:: Sendplay {LWin}{Up}
Offline Shogunner
« Reply #55 on: Tue, 24 January 2012, 21:32:30 »
Man.. respect you guys.
I've been trying to do a script that does what I want for the past few hours and it's been nothing but frustration. I just ended up using my Belkin n52te to control my media player. :P
Offline guilleguillaume
« Reply #56 on: Thu, 26 January 2012, 16:22:15 »
I ended up using Ripster's code from the first page since mine was causing some problems, very useful.
; Caps Lock becomes Ctrl, Win+LShift becomes Caps Lock
CapsLock::Ctrl
#Lshift::Capslock
Anyone knows how can I learn wich keycode send each key of the keyboard? I want to remap 5 of the Japanese keys I have left that right now don't have any use.
« Last Edit: Thu, 26 January 2012, 19:18:47 by guilleguillaume »
Offline alaricljs
« Reply #57 on: Thu, 26 January 2012, 16:25:28 »
PassMark KeyboardTest might be able to pull it off.
Offline pyro
« Reply #58 on: Thu, 26 January 2012, 16:36:22 »
Right click on the Autohotkey icon in the notification area
click Open
an Autohotkey window will open, click 'view' >> 'key history and script info' in the menu bar
press any series of keys and then hit F5
Offline no_mates
« Reply #59 on: Sat, 18 February 2012, 18:26:11 »
Can some someone please help I need to map the side button (#7) on my CM Spawn to the shift key for BF3.  There appears to be a bug with the Spawn where some modifier keys don't work even though the software say's they're mapped?
Offline shogrran
« Reply #60 on: Sun, 19 February 2012, 09:43:04 »
EDIT: Comment removed. I get it now thankee!
« Last Edit: Sun, 19 February 2012, 10:41:51 by shogrran »
Razer Blackwidow Elite
CMStorm Quickfire Rapid
[SIGPIC][/SIGPIC]
Offline BiNiaRiS
Re: AutoHotKey: Share your Scripts!
« Reply #61 on: Sat, 29 June 2013, 04:28:10 »
Scroll your mouse wheel over your windows taskbar and change your volume!
Code: [Select]
#If MouseIsOver("ahk_class Shell_TrayWnd")
WheelUp::Send {Volume_Up}
WheelDown::Send {Volume_Down}
MouseIsOver(WinTitle)
    MouseGetPos,,, Win
    return WinExist(WinTitle . " ahk_id " . Win)
Necroing the **** out of this thread to post a fixed version of this. Looks like no matter what, semicolons cannot be used for anything but comments. I couldn't get this to work until i replaced all the " with "
Running this on Win8 64 bit with no issues. Best script ever :D
KMAC 2 w/ErgoClears
Offline The_Beast
  • I like wood ಠ_๏
« Reply #62 on: Sat, 29 June 2013, 04:35:11 »
Not a bad thread to necro
Code: [Select]
;; Auto-Reload If Changes Are Made
SetTimer,UPDATEDSCRIPT,1000
UPDATEDSCRIPT:
FileGetAttrib,attribs,%A_ScriptFullPath%
IfInString,attribs,A
FileSetAttrib,-A,%A_ScriptFullPath%
SplashTextOn,,,Updated script,
Sleep,500
Reload
Return
Capslock::
Gui, 99:+ToolWindow
Gui, 99:Show, x-1 y-1 +NoActivate, Dummy IJKL to Arrow Keys
Keywait, Capslock
If A_ThisHotkey != Capslock
   Gui, 99:Destroy
else Gui, 99:Show, x-1 y-1 +NoActivate, Dummy IJKL to Arrow Keys +CapsToCancel
return
#IfWinExist, Dummy IJKL to Arrow Keys +CapsToCancel
Capslock::return
CapsLock Up::Gui, 99:Destroy
w::Up
a::Left
s::Down
d::Right
#IfWinExist
The top of the code is a simple updater. If you save an edit while the script is running, it autoupdates
The bottom is something to make the caps lock a 2nd layer. The cool thing about it is that if you press the caps lock, it locks the layer in. If you hold the caps lock then it doesn't lock and once you release it, it returns to the first layer
I didn't write either of these, but they are cool enough to share.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #63 on: Sat, 29 June 2013, 06:01:51 »
Anyone have any idea how to make the sleep button on my windows media center remote do alt+f4 instead of sleep?
Offline BiNiaRiS
« Reply #64 on: Sat, 29 June 2013, 12:38:19 »
I wouldn't even have the slightest clue. I'd be willing to bet you can't remap that button though. But if it had a scancode attached you'd be good to go.
KMAC 2 w/ErgoClears
« Reply #65 on: Sat, 29 June 2013, 17:36:09 »
it should have scamcode just like play pause or any of those other special keys. How would I figure it out? Would aqua key test do?
Offline Topre
« Reply #66 on: Sat, 29 June 2013, 17:52:37 »
Open the Autohotkey script by right clicking it on the taskbar then click Ctrl+K or go under View and click the option "Key history and script info."
« Reply #67 on: Sat, 29 June 2013, 22:23:42 »
alright ill get AutoHotkey on it and try it out i think i should probably disable sleep on the system temporarily as well so it doesnt enter sleep when i hit if you know what I mean.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #68 on: Sat, 29 June 2013, 22:37:22 »
Code: [Select]
f1::
Run, firefox.exe http://geekhack.org/index.php?action=pm
return
f2::
Run, firefox.exe http://geekhack.org/index.php?topic=38471.0
return
You should try this script TheProfosist. They're direct links to your PMs and to the GB thread. Hope this halps!
Offline laffindude
« Reply #69 on: Sun, 30 June 2013, 00:53:15 »
Code: [Select]
    MouseGetPos,,, Win
you need an escape char for semi colon. `; will work. (that's a grave accent).
Offline alrgeez
« Reply #70 on: Mon, 11 November 2013, 16:56:56 »
can someone help me with a script? would like alt+wheel up = volume up, alt+wheel down = volume down.
need to be able to control master volume control while gaming with my headphones.
i<3myKB
Offline Neal
  • Skype: iNewbcake
« Reply #71 on: Mon, 11 November 2013, 17:34:57 »
I'm pretty noobish at AHK, but this will do what you want:
Code: [Select]
LAlt & WheelUp::
SoundSet +1
Return
LAlt & WheelDown::
Soundset -1
Return
This is a script a friend made, it allows you to resize windows and puts them in a corner of the screen if you want to.
As you can see I use it for some random things. Mainly setting windows to  1920x1080, I use 2560x1440 res and I like to have most windows at 1920x1080
Code: [Select]
RCtrl & F5::
 ResizeWin(773,567,1)
return
RCtrl & F6::
 ResizeWin(720,480,1)
return
RCtrl & F7::
 ResizeWin(1280,720,1)
return
RCtrl & F8::
 ResizeWin(1920,1080,1)
return
ResizeWin(CW=0,CH=0,SnapToCorner=0)
WinGetPos,X,Y,W,H,A
If %CW% = 0
  CW := W
  If %CH% = 0
  CH := H
  If SnapToCorner = 1
  CX := A_ScreenWidth-CW
  CY := A_ScreenHeight-CH
  Else If SnapToCorner = 2
CX := 62
  Else
  CX := X
  CY := Y
  WinMove,A,,%CX%,%CY%,%CW%,%CH%
« Last Edit: Mon, 11 November 2013, 17:38:56 by Neal »
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #72 on: Mon, 11 November 2013, 18:29:39 »
Media keys on my shine 3.
Code: [Select]
SC121::Media_Stop
sc16b::Media_Prev
sc16c::Media_Play_Pause
sc132::Media_Next
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #73 on: Mon, 11 November 2013, 21:00:38 »
I no longer have that button, but iirc when I had it, I had to disable it in the control panel - maybe under power options - in order to keep the computer from sleeping. It seemed to send the sleep command before the key press would get picked up by AHK or whatever I was using.
"Obviously, windows are central to Windows. But what is a window?"
Offline alrgeez
« Reply #74 on: Tue, 12 November 2013, 14:24:49 »
Code: [Select]
LAlt & WheelUp::
SoundSet +1
Return
LAlt & WheelDown::
Soundset -1
Return
thanks Neal! it worked awesome but it ended up cycling through my weapons in game. so i changed the wheel up/down to the arrow keys.
i<3myKB
Offline Pacifist
  • on hiatus
« Reply #75 on: Wed, 27 November 2013, 21:16:18 »
Does anyone know the ahk code for my keycool 84's fn layer
specifically F1(which opens computer)
F2---google.com
F3 calculator
F4 music
the aquakeytest windows code is
182(0XB6)E
172(0XAC)E
183(0XB7)E
181(0XB5)E
thanks
« Reply #76 on: Wed, 27 November 2013, 22:02:52 »
RAlt::RCtrl or whatever it is lol I'm on my phone. I use right alt as control :-)
Offline atlas3686
  • HHKB Elite
« Reply #77 on: Thu, 28 November 2013, 00:57:12 »
Put this together, it makes alt+F2 open the selected file in Photoshop.
!F2::
ClipSaved := ClipboardAll
Clipboard =
ValidFiletypes = jpg png gif jpeg bmp tif pdf
Send ^c
ClipWait
FullPath := Clipboard
Loop, parse, FullPath, `n, `r
    IfNotExist, %A_Loopfield%
        continue
    SplitPath, A_Loopfield ,,, OutExt,
    IfInString, ValidFiletypes, %OutExt%
        run, photoshop.exe %A_LoopField%
Clipboard := ClipSaved
OutExt =
ClipSaved =
return
Offline Senbei
« Reply #78 on: Fri, 29 November 2013, 07:22:29 »
Hello folks,
my script is for using AltGr _instead_ of the Fn keys on my 60% Filco Minila.
(I would like, eventually, to replace the small space bar with a bigger one, thus I won't have the Fn anymore)
Code: [Select]
SendMode Input
; function keys
*<^>!SC002:: Send {Blind}{RAlt up}{F1}{RAlt down}
*<^>!SC003:: Send {Blind}{RAlt up}{F2}{RAlt down}
*<^>!SC004:: Send {Blind}{RAlt up}{F3}{RAlt down}
*<^>!SC005:: Send {Blind}{RAlt up}{F4}{RAlt down}
*<^>!SC006:: Send {Blind}{RAlt up}{F5}{RAlt down}
*<^>!SC007:: Send {Blind}{RAlt up}{F6}{RAlt down}
*<^>!SC008:: Send {Blind}{RAlt up}{F7}{RAlt down}
*<^>!SC009:: Send {Blind}{RAlt up}{F8}{RAlt down}
*<^>!SC00A:: Send {Blind}{RAlt up}{F9}{RAlt down}
*<^>!SC00B:: Send {Blind}{RAlt up}{F10}{RAlt down}
*<^>!SC00C:: Send {Blind}{RAlt up}{F11}{RAlt down}
*<^>!SC00D:: Send {Blind}{RAlt up}{F12}{RAlt down}
*<^>!SC02B:: Send {Blind}{RAlt up}{PrintScreen}{RAlt down}
*<^>!SC00E:: Send {Blind}{RAlt up}{ScrollLock}{RAlt down}
*<^>!SC001::
GetKeyState, state, Ctrl
if state = D
Send {Blind}{CtrlBreak}
else
Send {Blind}{Pause}
Send {Blind}{RAlt down}
return
; cursor block
*<^>!Up:: Send {Blind}{RAlt up}{PgUp}{RAlt down}
*<^>!Down:: Send {Blind}{RAlt up}{PgDn}{RAlt down}
*<^>!Left:: Send {Blind}{RAlt up}{Home}{RAlt down}
*<^>!Right:: Send {Blind}{RAlt up}{End}{RAlt down}
*<^>!Del:: Send {Blind}{RAlt up}{Ins}{RAlt down}
; tilde on dot
*<^>!SC034:: Send {Blind}{RAlt up}{SC029}{RAlt down}
Minila [brown]
« Reply #79 on: Sat, 30 November 2013, 13:09:20 »
!F2::
Clipboard =
Send ^c
ClipWait
        continue
OutExt =
ClipSaved =
return
Now that's a cool idea!!!
Offline atlas3686
  • HHKB Elite
« Reply #80 on: Tue, 03 December 2013, 02:16:56 »
Thanks ,I right click, open with, so often that it just makes so much sense. Need to figure out how to do the same thing on my Macbook now.
« Reply #81 on: Tue, 03 December 2013, 02:55:22 »
Any way to auto load the program at start up? Thanks !
Offline CeeSA
« Reply #82 on: Tue, 03 December 2013, 07:27:45 »
do you mean in windows? A Link in "Autostart" could be the solution....
Offline atlas3686
  • HHKB Elite
« Reply #83 on: Tue, 03 December 2013, 08:21:44 »
Yup I have done it, there is a little program that comes with Autohotkey that turns your script into an exe then you just set that exe to run at startup.
Offline thegagne
« Reply #84 on: Tue, 03 December 2013, 08:36:25 »
I need some suggestions on what to do with the 24 Fkeys on my Cherry 8113. :rolleyes:
Maybe changing audio output device?
Maybe speed up / slow down case fans?
Maybe League of Legends macro to buy champ-specific starting items?
That accounts for maybe 4...
What else?
« Reply #85 on: Tue, 03 December 2013, 10:04:27 »
Thank you very much! I use quick start.
Offline Neo.X
« Reply #86 on: Tue, 03 December 2013, 13:15:34 »
Mine is very simple, Press a key to hide the active browser window, save my *** when boss come by.  ;)
  DetectHiddenWindows, on
     if WinExist("ahk_class IEFrame")
               WinHide
  DetectHiddenWindows, off
  return
!1::
               WinShow
  return
All those keyboards will be lost in time....
Offline Frenir
  • HHKB Viking
« Reply #87 on: Wed, 25 June 2014, 08:39:07 »
I made this simple script for HHKB users in Nordic countries. It adds backslash and Less/Greater than symbols.
Code: [Select]
; Nordic HHKB Function - Less/Greater Than "<" ">"
; Left Alt + Z = "<"
!z::
SendInput {<}
return
; Left Alt + Shift + Z = ">"
+!z::
SendInput {>}
return
; Nordic HHKB Function - Backslash "\"
; Right Alt + Z = "\"
<^>!z::
SendInput {\}
return
Also, sorry for necro - I just wanted to share in case someone would find it useful.
Offline lakiozoon
« Reply #88 on: Mon, 14 July 2014, 12:12:35 »
Anyone with a script that remaps keys while scroll-lock is on?
I'dd like to remap jkl area as a numpad while using scroll-lock.
Various scripts i've dug up googling don't work properly:(
Offline Neo.X
« Reply #89 on: Mon, 14 July 2014, 13:37:56 »
What I am using now for number pad replacement.
!j::Send 1
!k::Send 2
!l::Send 3h
!u::Send 4
!i::Send 5
!o::Send 6
!7::Send 7
!8::Send 8
!9::Send 9
!m::Send 0
!.::Send .
Offline lakiozoon
« Reply #90 on: Mon, 14 July 2014, 16:41:20 »
That one will come in handy, thanks!
I would like to have a workaround with scroll lock tho, all solutions i've tried produced errors of some kind.
Again, thanks for the effort.
Offline s0hei
« Reply #91 on: Wed, 16 July 2014, 11:11:43 »
does anyone have a script for changing capslock -> fn? sorry for the stupid question
Offline Phenix
« Reply #92 on: Sat, 02 January 2016, 04:01:59 »
rarher use Foobar2000 for music and audiobooks than winamp.Way more customizable
Winter is coming.
Offline Coreda
« Reply #93 on: Sat, 02 January 2016, 04:19:14 »
I keep a bunch in a collective mega-script.
A few examples (stripped of the standard top-of-script stuff like #NoEnv, etc) :
Auto-expand the Volume mixer panel window (credit: GeekDude):
Code: [Select]
Title = ahk_class #32770 ahk_exe sndvol.exe
Loop
    ; ToolTip, Searching
    WinWait, %Title%
    ; ToolTip, Found
    Winmove, %Title%,,,,900,
    WinWaitClose, %Title%
Minimize windows by middle-clicking on their titlebar (once you try it you'll never go back, source):
Code: [Select]
#If MouseIsOverTitlebar()
MButton::WinMinimize
+MButton::WinClose
MouseIsOverTitlebar() {
    static WM_NCHITTEST := 0x84, HTCAPTION := 2
    CoordMode Mouse, Screen
    MouseGetPos x, y, w
    if WinExist("ahk_class Shell_TrayWnd ahk_id " w)  ; Exclude taskbar.
        return false
    SendMessage WM_NCHITTEST,, x | (y << 16),, ahk_id %w%
    WinExist("ahk_id " w)  ; Set Last Found Window for convenience.
    return ErrorLevel = HTCAPTION
Send clipboard to the command prompt / PowerShell using Ctrl+V:
Code: [Select]
#IfWinActive ahk_class ConsoleWindowClass
^V::
SendInput {Raw}%clipboard%
return
#IfWinActive
Paste clipboard contents as plaintext in Wordpad using Ctrl+Shift+V (source):
Code: [Select]
#IfWinActive, ahk_class WordPadClass            ; WordPad
^+v::
Clip0 = %ClipBoardAll%
ClipBoard = %ClipBoard% ; Convert to plain text
Send ^v
Sleep 1000
ClipBoard = %Clip0%
VarSetCapacity(Clip0, 0) ; Free memory
Return
« Last Edit: Sat, 02 January 2016, 04:20:45 by Coreda »
Offline Lunatique
  • Writer, Composer, Artist, Photographer, Gamer
« Reply #94 on: Sat, 09 January 2016, 04:02:38 »
For those of you who experience stability issues with AHK and don't need complex scripts, a much more stable and intuitive alternative is TouchCursor (although it is much simpler). But if TouchCursor can do all the things you want already, then definitely use it over AHK.
Offline Questengine
    • Heroglyphix Nonogram Logic Puzzles
« Reply #95 on: Thu, 26 May 2016, 12:01:15 »
Here's a couple cool ones for coders.
Type an "if" condition, like "somevar = 2" then hit alt-i and it builds an if statement around that, comments the condition after the closing brace, and puts the cursor in the body of the "if" after a tab
e.g.
type: "somevar = true"
hit alt-i
get:
Code: [Select]
if(somevar=true){//
}//end if--somevar=true
And then alt-e does the same thing but for an if/else statement
Code: [Select]
;;do "if"
!i::
;;save what's currently on the clipboard
varClipSaved :=ClipboardAll
Sleep, 133
Send {Shift down}{Home}{Shift up}^c
Sleep, 133
Send if`(
Send %Clipboard%
Send `){{}{/ 2}{Enter 2}{}}{End}{/ 2}end if--
Send %Clipboard%
Send {Up }{End}{Tab}
;;restore what was originally on the clipboard
Clipboard := varClipSaved
;;empty that temp clipboard variable, to free that memory (in case you had a lot of crap there)
varClipSaved :=
return
;;do "if/else",
!e::
Sleep, 133
  Sleep, 133
Send if`(
Send %Clipboard%
Send %Clipboard%
Send {Enter}else{{}{Enter}{Tab}{Enter}{}}{/ 2}end else--
Send %Clipboard%
Send {Home}{Up 4}{Tab}
varClipSaved :=
return
And a couple expansions that are obvious, but you probably aren't using.  Why type 6 characters when you can type 2?
Code: [Select]
::fff::function
::sss::select * from
::pv::private
::pb::public
::pt::protected
And a couple just for Unity and/or 3D programming:
Code: [Select]
::vv::Vector3
::vz::Vector3.zero
::vd::Vector3.Distance(){Left}
::qqq::Quaternion
::gg::gameObject  ;; gg doesn't come up too often naturally
::pp::transform.position  ;;similarly, pp is pretty safe
::rrt::transform.rotation  ;; tr, rt, and rot, are to common for this, so rrt has to suffice.
