Author Topic: mouse that's make big "click"?  (Read 3669 times)
Offline brkim1324
« on: Sat, 14 May 2011, 02:13:54 »
I am looking for a mouse that's comfortable, not TOO old,
and makes good "click" sound :)
any recommendations?
Offline Arc'xer
« Reply #1 on: Sat, 14 May 2011, 04:39:03 »
Pretty much any mouse for that matter. Most mice use the same model Omron, TTC, and or Zippy microswitches. Your not gonna find many mice out there with different versions unless you mod your own and for research of the microswitches it's tough since there isn't a GH of mice microswitches round. Sometimes the body of the mouse, material, and shape can change the sound and or tone but then again the switch itself is the same common models used.
I'm sure there's "more clicky" versions out there but I doubt it's going to be easy to find.
« Last Edit: Sat, 14 May 2011, 04:42:01 by Arc'xer »
Offline vun
  • Just one more thing
« Reply #2 on: Sat, 14 May 2011, 04:41:41 »
Check out the Razer Diamondback. I have no proof that it's louder than other mice, but day9 uses it and whenever I watch the daily I can't get over how loud his mouse sounds. Might just be the mic, though, but worth taking a look at.
