Author Topic: Beep / getting stuck  (Read 3207 times)
Offline domin8r
« on: Tue, 17 May 2011, 03:11:22 »
I have a Laser keyboard with SMK switches (quite nice actually).
I've used it for some time at home but ran into some issues. Whenever I'm typing really fast or playing COD4 I occasionally get a "system beep". The beep itself isn't too bad but it also means that a key gets "stuck" and keeps getting triggered for a few seconds, highly annoying!
The strange this is that when I brought it to work it NEVER had any of these symptoms.
Now that I have a model M at work I want to bring the Laser back home but would love to know if this problem can be fixed. The fact that it doesn't happen on my work machine gives me hope it can.
Here's the setup :
Home : Din -> PS/2 adapter (computer has PS/2 input)
Work : Din -> PS/2 adapter, PS/2 -> USB convertor
Any help is appreciated ofcourse !:)
Compaq MX-11800, Ergo Clear/Brown/Ghetto Red
Ducky 1087XM
Laser SX-25 , White SMK
Black Dell AT101W
IBM Model M 1390120 (\'86)
Cherry G80-1000, Panda Clears
Offline Human
« Reply #1 on: Tue, 17 May 2011, 04:13:59 »
Inb4 blue cube
Offline domin8r
« Reply #2 on: Tue, 17 May 2011, 04:21:09 »
Quote from: Human;347425
Inb4 blue cube
It works with current PS/2 -> USB convertor.. so it's not a Blue Cube thing :)
The weird thing is working weirdly with just the DIN->PS/2 adapter (which would seem less of a problem)
Ducky 1087XM
Black Dell AT101W
Offline Mr. Perfect
« Reply #3 on: Tue, 17 May 2011, 09:45:04 »
Silly question here, but have you tried the same setup at home that you have at work? The DIN -> PS/2 -> USB route?
The only time I've heard the PC system speaker go off while using a keyboard is when pressing more keys then a board can handle(rollover problems). In those cases though, the key that triggers the problem does not register at all, so it doesn't really sound like what you've got going on. :noidea:
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline domin8r
« Reply #4 on: Tue, 17 May 2011, 13:53:55 »
@Mr. Perfect.. No have not tried that, it's worth a shot :) (It is a weird problem indeed)
@Ripster it's the switch in the bottom image. I can understand the concept of NKRO, but is that something a PS/2 to USB convertor would/could solve?
Thanx for the replies so far guys!
Ducky 1087XM
Black Dell AT101W
Offline Human
« Reply #5 on: Tue, 17 May 2011, 14:37:44 »
Quote from: domin8r;347616
Just i stated just now, not all adapter can change PS/2 to USB perfectly. That's why GH always become Blue Cube fanboi.
Offline domin8r
« Reply #6 on: Tue, 17 May 2011, 16:20:42 »
Quote from: Human;347629
I think I might have not explained it properly.. but the keyboard was only giving the problems WITHOUT the PS/2 to USB convertor (computer with native PS/2 port)
Ducky 1087XM
Black Dell AT101W
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #7 on: Wed, 18 May 2011, 07:36:30 »
You don't have the error signalling functionality over USB. (My Belkin adapter will usually clear all keystrokes then.) Usually when the system beeps at you with a PS/2 connection, it means you've hit some combination of >=3 keys that cannot be accepted on this particular board. Try using Aquakeytest or whatever to reproduce it.
Offline domin8r
« Reply #8 on: Wed, 18 May 2011, 08:47:37 »
Quote from: ripster;347947
Keep collecting nickels.
I want to find out how stiff those white SMKs are.
I think I'll go and weigh my euro-trash change to see what could replace a nickel ;)
Ducky 1087XM
Black Dell AT101W
Offline domin8r
« Reply #9 on: Wed, 18 May 2011, 08:51:26 »
Quote from: ripster;347950
Euro dime.  4.10g.  Keep it centered, put notepad up, and stack until it registers a keystroke.
Details here:  RipOmeter.
Hehehe, you have an answer for everything :D
Ducky 1087XM
Black Dell AT101W
woody
  •  Guest
« Reply #10 on: Wed, 18 May 2011, 17:32:04 »
Change is inevitable, except from a vending machine.
(author unknown)
Offline domin8r
« Reply #11 on: Thu, 19 May 2011, 04:40:13 »
Ripster,
12 "euro-dimes" still weren't enough.. so I tested it by adding other change to it. Finally clicked at 12 x 10c, 3 x 20c and 1x 5c. Went to the mailroom at work and used their scale to see how much that ended up to be.
Scale said it was 70 grams
Ducky 1087XM
Black Dell AT101W
Offline Zet
« Reply #12 on: Fri, 20 May 2011, 11:43:07 »
It might be that your PS/2 ~ USB connector is not working properly, I believe too is a KRO problem. What about the OS on both computers?
Offline Mr. Perfect
« Reply #13 on: Fri, 20 May 2011, 18:51:35 »
Maybe because of the granularity? With nickels you can only measure to the nearest 5grams. :shocked:
Offline domin8r
« Reply #14 on: Fri, 20 May 2011, 18:59:38 »
Quote from: Zet;349007
Could be a thing... Windows XP at home  and Windows 7 at work
Ducky 1087XM
Black Dell AT101W
