Author Topic: Filco and cherry keycap comparison  (Read 3332 times)
Offline What's that? It's NEO!
« on: Tue, 17 May 2011, 07:03:24 »
Hi, now that I have the filco tenkeyless, I wanted to swap the keys with the cherry g80-3000. These caps are lasered, thicker and of shorter height. It's all settled, only 'space' and 'caps lock' are annoying me as they have off-centered stabilizers. I still have to figure out what to do about them.
1) weight filco spacebar
2) weight cherry spacebar
3) height: cherry on the left, filco on the right
4) thickness: filco on top
5) off-centred: filco on top
6) cherry caps on filco board with removed spacebar
Accidentally posted this on the pointing devices side first...
« Reply #1 on: Tue, 17 May 2011, 12:15:21 »
Has anyone tried to built in some replacement stabilizer holders to fit the cherry spacebar onto the filco board?
« Reply #2 on: Tue, 17 May 2011, 12:40:00 »
Sure, if i had the money for this thing, I wouldn't even worry about the stabilizers not fitting I would just go and get a whole new set of keycaps instead... that would even save me 5 minutes!
Guess I have to keep thinking...
« Reply #3 on: Tue, 17 May 2011, 13:32:53 »
It's definitely a majestouch 2 tenkeyless brown - at least I ordered a 2nd generation and the box it came in told me so.
« Reply #4 on: Tue, 17 May 2011, 14:21:11 »
Found a new method, just have to see how it turns out...
1) took this art tool and caved out the cherry cap to house the stem
2) sculptured a new stem holder out of some playdough - with the help of a stabilizer
3) let it dry, glue it onto the cap and let it dry again
Have to do the same with caps lock.
