Author Topic: Looking for good quality Cherry Brown mechanical keyboard with at least 1 USB port  (Read 2329 times)
Offline Viper2
Hello,
I am looking for a very good quality Cherry Brown mechanical keyboard (with ten key) with at least one USB port (preferably 2) on it.  I will be using it for typing and gaming, however it doesn't have to have special gaming keys or features.
Any suggestions?
Thank you very much.
Offline brkim1324
Das Keyboard has 2 USB ports. and very good mechanical keyboard.
the only con is.. the USB ports are on the right... which is just bad for right handy
Offline noodles256
  • le legendary
wlcm 2 gh!
das is a very good option! would be my first choice. might wanna look at the zowie celeritas as well, i believe that might have usb ports
AF | Ducky YOTD |
Offline brkim1324
woo I forgot. :(
Welcome to GH! XD
Offline Viper2
Thanks for the responses so far.
It seems like the DAS keyboard's USB ports are not located where I would like them to be, therefore, I think I will just go for a Cherry Brown mechanical keyboard without additional USB ports.  In that case, would the Filco Majestouch-2 (FKBN104M/EB2) be the best choice?  I don't want one with a built-in wrist rest.
Offline noodles256
  • le legendary
if you don't need the usb ports, you have a lot of options.
filco is a very good choice though, at least everyone here loves it
except for one
dun dun dun
AF | Ducky YOTD |
