Author Topic: Upside down Filco switches  (Read 9548 times)
Offline turtleslikejohn
« on: Tue, 17 May 2011, 21:23:15 »
Upside down Filco switches whaaaaaaat, I'm pretty sure this isn't normal.
[ Attachment Invalid Or Does Not Exist ] 18251[/ATTACH]
« Last Edit: Tue, 17 May 2011, 21:27:14 by turtleslikejohn »
Offline HaveANiceDay
« Reply #1 on: Tue, 17 May 2011, 22:05:57 »
It is.
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
Offline Tony
« Reply #2 on: Tue, 17 May 2011, 22:06:52 »
That's working, but you should pull it out and put it the right way.
« Reply #3 on: Tue, 17 May 2011, 22:10:45 »
Quote from: Tony;347802
It's hard to tell if someone is joking on the internet.
Offline Zet
« Reply #4 on: Tue, 17 May 2011, 22:11:00 »
did you just bought your keyboard?
Offline Orphagn
« Reply #5 on: Tue, 17 May 2011, 22:12:21 »
lol +1
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
« Reply #6 on: Tue, 17 May 2011, 22:24:55 »
Quote from: Zet;347807
Yeep last week, I actually kind of regret it; I like the browns over the blues.
Offline Tony
« Reply #7 on: Tue, 17 May 2011, 22:26:34 »
You can always buy another brown. Most of us do so, and regret more.
« Reply #8 on: Tue, 17 May 2011, 22:33:37 »
Quote from: Tony;347818
I actually wanted reds, but damn bastards took em all. A week later, everyone's selling them because they fell for the hype. Silly children.
Offline Tony
« Reply #9 on: Tue, 17 May 2011, 22:41:37 »
We are all children anyway. Just replace what we sucks from candies to keyboards.
Offline godofdeath
« Reply #10 on: Tue, 17 May 2011, 23:52:00 »
is it tenkeyless or 104 key?
Offline brkim1324
« Reply #11 on: Wed, 18 May 2011, 00:26:27 »
I have... all of them that you talked about.. lol
but I am not satisfied with them 100 percent.
It's just that you get greedy and greedier as you get something. It's human nature!! WANT MORE!!! XD
Offline The Solutor
« Reply #12 on: Wed, 18 May 2011, 03:06:30 »
Great news, maybe filco is thinking to built a good keyboard ?
I'm sure ripster will be proud to see filco start cloning xarmor....
Offline Zet
« Reply #13 on: Wed, 18 May 2011, 12:31:56 »
Quote from: turtleslikejohn;347817
return it then, and show them the problem.
Really bad luck that this happend to you man, better luck next time...
PS: I've got the 8th last one filco majestouch2 red full layout :x
Offline noodles256
  • le legendary
« Reply #14 on: Wed, 18 May 2011, 13:40:57 »
did expect to see boob in this topic.
I remember reading somewhere about the upside down keys, but don't know what was exactly discussed in that topic, oh well.
AF | Ducky YOTD |
Offline Reaif
« Reply #15 on: Wed, 18 May 2011, 14:00:19 »
I believe that having the switch be upside down is for LEDs as was mentioned earlier. I seem to remember hearing somewhere that most backlit boards have them upside down because it puts the LED closer to where the legend on the keycap is.
Currently own:
Das S Ultimate with Browns
Cherry G84-4100 with ML Linear switches
Memorex Telex with NMB Space Invaders
Leopold with Blues
« Reply #16 on: Wed, 18 May 2011, 14:02:31 »
Quote from: Reaif;348082
But it's a Filco.. No backlighting. And it's kind of strange that all the keys are in the proper orientation except these two. I'll try and return it :/
Offline Reaif
« Reply #17 on: Wed, 18 May 2011, 14:05:20 »
Honestly, I wouldn't worry about it unless it is causing a problem. Though I can understand if OCD starts to kick in and bug you about it. It seems like a number of members here are kind of OCD about their desk space...
Currently own:
Leopold with Blues
Offline elborak
« Reply #18 on: Wed, 18 May 2011, 17:01:58 »
Wıuǝ ıs ʇɥǝ sɐɯǝ ʍɐʎ ɐup I ɹǝɐllʎ pou,ʇ sǝǝ ɐ dɹoqlǝɯ˙˙˙
Offline The Solutor
« Reply #19 on: Wed, 18 May 2011, 17:22:02 »
Quote from: ripster;348060
What a bunch of trolls.
All Gen2 Filcos are that way.
You never mentioned this interesting fact when people asked about the differences between gen1 and gen2
« Reply #20 on: Wed, 18 May 2011, 17:25:44 »
Quote from: The Solutor;348173
To be honest, I don't think it was supposed to be that way, contrary to what people think, because having upside down switches only on the left window and alt key is so arbitrary; I don't see Diatec's reasoning for doing this, so I'm assuming it was a mistake.
Offline The Solutor
« Reply #21 on: Wed, 18 May 2011, 18:32:46 »
Quote from: ripster;348201
It's bad enough nobody reads the Wikis I write carefully.
Frankly I don't care much about filcos, whit the exception of filco mini, so I read the related infos just when I encounter it.
BTW wiki are mostly well written but is a mess.
Until some better engine will be used we need a wiki of wiki, a single stick thread wit more interesting threads linked on it.
Offline Arc'xer
« Reply #22 on: Wed, 18 May 2011, 21:55:06 »
Quote from: turtleslikejohn;347786
(Attachment Link) 18251[/ATTACH]
Not sure why your freaking out about it. Pretty much all the backlight cherry mx switches are placed that way(Deck legend upside down)
I posted a thread on this a while back and also replied to another which my response was deleted due to the new theme changes and update.
It's actually an interesting thing because if you do a comparison between a standard placement and the upside down. The upside down switch tends to produce a better tactile response and feel. In simplest terms the upside down switches have their tactile point or linear slide placed towards the fingertips rather than towards the fingernails. So you press the switch towards the nerve endings rather than against them with the nails.
And as I said you also get a better feel of the switch tactility and also in the linear switches you feel a sort of wall giving support as you press down. Some people might say that orientation shouldn't matter but to me it does.
« Reply #23 on: Wed, 18 May 2011, 22:08:45 »
Quote from: Arc'xer;348289
I wasn't really freaking out, just filled with curiosity why every single switch except those two were in that orientation. I am aware that several companies mount it like this for backlighting, but it's just so weird that all but two switches are like that.
Offline bpiphany
« Reply #24 on: Thu, 19 May 2011, 06:55:15 »
One reason to have the switches in odd orientation might be to facilitate optional switch placement on the same pcb. It makes it possible to have two different switch positions in close proximity without soldering pads overlapping. I have no idea if this is the case. The "generation 1" filcos are done that way, not on the part left of spacebar though.
Offline Zet
« Reply #25 on: Thu, 19 May 2011, 08:37:22 »
I would be scared if it was only on one keyboard in the production, but if it is on all the majestouch 2 series/generation then they did it for a reason and trusting the company enough to live with it. Besides, its represents no problem at the time of typing so... chill!
Offline The Solutor
« Reply #26 on: Thu, 19 May 2011, 08:40:16 »
Quote from: Zet;348453
You can mount a switch upside down only if the PCB is purposely designed to accept it. Is not possible to mount a switch with a different orientation by mistake.
Offline Zet
« Reply #27 on: Thu, 19 May 2011, 09:35:35 »
Quote from: The Solutor;348455
Right dear Solutor, so unsoldering the switch and turning it upside up, and downside down, would make it worst, since altho~ right now it's upside down, it is working properly.
And I agree that this is something ripster coulda have mentioned when so many threads have been open asking the diferences...
knowledge is power, but we are here to share power then.
« Reply #28 on: Thu, 19 May 2011, 09:47:00 »
Quote from: ripster;348474
Not me.  If I shared power outside the Wikis I'd no longer be the #1 Keyboard expert on the Planet.
You are more like the blendtec guy. Doing fun ****, breaking stuff - for science.
« Reply #29 on: Thu, 19 May 2011, 10:08:41 »
They cost a lot, so they must be good. Right? RIGHT?
Offline Zet
« Reply #30 on: Thu, 19 May 2011, 11:36:58 »
then you are ruined, people will start gathering power with the search engine and no longer need you lol perhaps one day there will be many ripsters around with the same knowledge...
you think you are special Fett? theres a clone army on their way here!
« Last Edit: Thu, 19 May 2011, 11:39:17 by Zet »
« Reply #31 on: Thu, 19 May 2011, 11:38:19 »
Quote from: Zet;348544
Some things NEVER change.
Offline bpiphany
« Reply #32 on: Thu, 19 May 2011, 15:28:10 »
Wait, didn't I post the answer to this earlier today?.. How ignorant of the surrounding world is it possible to get? Did anyone ever look at the pin-out of a mx-switch? I'm not going to help on that now, but I might post a pic tomorrow if someone still doesn't get it, although I doubt it will do any good =P Now I need to sleep.
There, I hope that was wise-ass enough =D
Offline bpiphany
« Reply #33 on: Fri, 20 May 2011, 02:13:24 »
Sorry about the blur but I couldn't get it any flatter against the scanner...
Actually it looks like that ctrl key would have two possible orientations in the same location.
Offline petersam
« Reply #34 on: Fri, 20 May 2011, 03:23:24 »
Dopo le droghe come Viagra e Cialis ha rivoluzionato il trattamento di disfunzione sessuale maschio verso la fine degli anni 90, un turbine di neve dei test clinici sono stati condotti in donne nelle speranze che le droghe potrebbero fare lo stessi per fare rivivere l'azionamento di sesso diminuente della donna.
Offline elef
« Reply #35 on: Fri, 20 May 2011, 04:16:03 »
WOW the Italian is almost entirely correct here, a step up from the usual garbled spammer Engrish. It's a shame it's just a random excerpt from some half-scientific article.
Offline The Solutor
« Reply #36 on: Fri, 20 May 2011, 04:54:54 »
Quote from: elef;348900
Not really, google translate is just getting (slightly) better.
Offline The Solutor
« Reply #37 on: Fri, 20 May 2011, 04:57:19 »
Quote from: PrinsValium;348889
Ok. Now is clear.
They use some switch upside down to use the same PCB for different phisical layout, like ducky.
Offline The Solutor
« Reply #38 on: Fri, 20 May 2011, 09:52:10 »
Quote from: ripster;348949
Looks like they wanted one PCB for JIS/ANSI/ISO stuffing options.
I told you guys Japanese Engineering>German Engineering>Taiwanese Engineering>Chinese Engineering.
Indeed the super genius from japanese filco, managed to clone the chinese ducky's PCB.
Offline Zet
« Reply #39 on: Fri, 20 May 2011, 10:39:02 »
I just gave a close look to a picture I've found on the internet, to the keyboard I'm getting (already bought, waiting for it to get delivered to me), the Filco Majestouch 2 104 layout with Red Switches, and if you pay close attention to the picture, you can actually see that in this case, the switches from the left are ok (ctrl+alt+win+etc) but unlike the case of the blue ones from the OP, this model with red switches have the right keys upside down: menu+ctrl+alt?
The rest of the keys are correctly placed.
Weird huh?
PS: I didn't attach the picture, not edit with a circle showing the switches upside down, cause I'm on the office, 'working' ^_^
Offline Zet
« Reply #40 on: Fri, 20 May 2011, 11:36:52 »
Quote from: ripster;348995
What's not OK with them being upside down?  You have something against Australians or Brazillians?  Or South Africans?  It's not their fault they are upside down.
Are you referring to me, about my last post?
Offline Zet
« Reply #41 on: Fri, 20 May 2011, 18:10:18 »
I'm now uploading the image with notes belonging to the Filco Majestouch 2, with red switches (I believe this layout is the full japanese layout), since I just got out of the office, so just people can see clearly of what I mean.
BTW: I don't think switches upside down are wrong, since all backlight keyboards have them(or 99%)
« Last Edit: Fri, 20 May 2011, 18:17:04 by Zet »
Offline The Solutor
« Reply #42 on: Fri, 20 May 2011, 18:12:24 »
Quote from: Zet;349197
Definitely
