Author Topic: So I just bought some dental cleaning tabs :)  (Read 3919 times)
Offline calavera
« on: Thu, 19 May 2011, 00:21:12 »
No, not for me. I'm too young for that ;) I bought a over the counter dental cleaning tabs to clean my key caps. I doubt they'll do anything to damage my key caps but just wondering if anyone had any mishaps while cleaning theirs with stuff like this?
I figure I'll just dump all the key caps in a big bowl with water and add a few tablets and let them sit for a while. I'm too lazy to find that cleaning key caps thread. :P So I should be good right?
Offline domin8r
« Reply #1 on: Thu, 19 May 2011, 01:50:21 »
That sounds about right :)
Compaq MX-11800, Ergo Clear/Brown/Ghetto Red
Ducky 1087XM
Laser SX-25 , White SMK
Black Dell AT101W
IBM Model M 1390120 (\'86)
Cherry G80-1000, Panda Clears
Offline Ascaii
Offline chongyixiong
« Reply #3 on: Thu, 19 May 2011, 02:58:09 »
I usually do this in a huge bucket with like 5-6 tabs, some warm water, and all my keyboard caps - Topre, Filco, IBM.
Meh, nothing explosive or corrosive so far so I guess you're good to go!
Stir it around when the tabs are dissolving and I always remove the metallic parts
Offline calavera
« Reply #4 on: Thu, 19 May 2011, 03:15:52 »
Arghhh, why warm water? Does it break up dirt better/quicker? I already cleaned them with cold water and with somewhat disappointing results. May be I should give it another go with warm water. :( How long am I supposed to let them sit there?
I used two tablets and the water had a blue tint to it at the beginning. After awhile (forgot how long) the water became transparent again...
Offline Ascaii
« Reply #5 on: Thu, 19 May 2011, 03:18:54 »
i use warm, near hot water and let them soak for about 30-60 minutes
Offline calavera
« Reply #6 on: Thu, 19 May 2011, 03:35:39 »
Damn, I'll give them another go tomorrow but I don't think these key caps will become any more "cleaner" than they were originally. But we'll see. Thanks for the info :D
Offline BaconKnight
« Reply #7 on: Thu, 19 May 2011, 03:39:47 »
Maybe it depends on the brand but when I did it, the water turned deep blue/green. Reminded me of a toilet after putting those disinfection tabs in em. Was with warm water, 5 tabs, and stirred it up a bit. Did a little hand washing of the keys too. Not sure if it'll make em cleaner but it can't hurt so I don't see why not.
Leopold FC200RC/AB
Noppoo Choc Mini
TG3 Data911
Cherry G80-8113LRCUS
IBM Model M 1391401
SIIG Minitouch 1903
Dell AT101W GYUM90SK
Image Gallery
Offline Ascaii
« Reply #8 on: Thu, 19 May 2011, 03:58:21 »
too hot water can warp some keys, depending on the plastic. WARM water wont hurt keys...meaning...DONT USE A WATER COOKER^^
boiling water is a nono.
My method is...if it doesnt hurt me, it doesnt hurt the keys. So just feel the water, if it burns you, let it cool down a bit before throwing in your caps.
Offline calavera
« Reply #9 on: Thu, 19 May 2011, 04:06:29 »
If it's just warm water I don't see how it could warp any sort of plastic.
I mean I'm talking about cherry corps key caps like double shot and/or dye sub. (NOT filco or any other thin key caps that look like it could be pierced through just by starring at them intensely lol)
Offline Ascaii
« Reply #10 on: Thu, 19 May 2011, 04:16:16 »
some plastics can get warped or bleach out color at ~60-80° c. So beware the dish washer with some caps....too lazy to look for the post of the guy that had this happen to him^^
« Reply #11 on: Thu, 19 May 2011, 05:13:11 »
Many brands of cleaning tabs contain bleach that does not work if the water is not warm enough.
Offline calavera
« Reply #12 on: Thu, 19 May 2011, 05:23:06 »
Quote from: Findecanor;348405
Good point. I just checked the box and it says use warm water. doh!
Ingredients: potassium monopersulfate, sodium carbonate, sodium perborate, TAED, citric acid, corn starch modified, flavor, microcrystalline, cellulose, hydrogenated rapeseed triglyceride, sodium lauryl sulfoacetate, tetrasodium EDTA, hydrated silica, sorbitol, dimethicone, copolymer, cetyl dimethicone copolyol.
Alright I don't know any of the ingredients but anyone have the slightest clue as to if anything could hurt the plastic? :P
I did enjoy typing all that with cherry blues I might add.
Offline BaconKnight
« Reply #13 on: Thu, 19 May 2011, 06:18:41 »
My thinking is, if it's good enough for grandma's old fake teef, it's good enough for my keycaps.
Leopold FC200RC/AB
Noppoo Choc Mini
TG3 Data911
IBM Model M 1391401
SIIG Minitouch 1903
Image Gallery
Offline Zet
« Reply #14 on: Thu, 19 May 2011, 09:46:45 »
lol so you think filco keycaps would not survive this?
Offline calavera
« Reply #15 on: Thu, 19 May 2011, 19:00:30 »
Quote from: Zet;348479
No I was just being sarcastic and making fun of how thin filco key caps are. I don't really like thin key caps, although they're great with cherry blues.
Offline RiGS
« Reply #16 on: Thu, 19 May 2011, 19:04:36 »
Actually it is harder to produce thinner keycaps.
Offline calavera
« Reply #17 on: Fri, 20 May 2011, 00:35:11 »
Alright I cleaned them again with warm water now. They do seem cleaner now but not by much. I think I'll clean all my key caps this way from now on. :)
Will upload pics but doubt you'll notice anything different. lol
Offline False_Dmitry_II
« Reply #18 on: Fri, 20 May 2011, 01:19:10 »
Lol. I didn't think rapeseed was actually a thing.
Sodium perborate, huh? What's the "Active Ingredient" if it tells you that? If it is the active ingredient itself, then using stuff like oxyclean will be fine.
Personally I like the dishwasher method. No left over substances that way.
Offline Oqsy
« Reply #19 on: Fri, 20 May 2011, 03:02:33 »
TAED is whats in oxiclean / retrobrite, right?  Soaking in sunlight could have nice color-restoring effects on yellowed keys.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
« Reply #20 on: Fri, 20 May 2011, 03:14:34 »
Quote from: calavera;348869
Not sure if it makes any difference because I have always performed this.
While waiting for it to dissolve, I shake it vigorously in the warm water - the keys rubbing against each other also helps to remove grime I believe.
Maybe it works for you, or it doesn't.
