Author Topic: MX Cherry Clear switches, alone or on keyboard.  (Read 3283 times)
Offline Wibox
  • Trade Count: (0)
« on: Thu, 19 May 2011, 13:13:26 »
Hi. I would like to purchase some Cherry MX Clear switches. Preferrably just stand-alone, but I will accept them on a keyboard aswell. I am using these to change my switches to "Ergo" clears.
Thanks much!
« Last Edit: Thu, 19 May 2011, 13:23:56 by Wibox »
!! YKBDS !! - KBC Poker (Ergo Clear Cherry) - Apple M0116 (Pink ALPS) - Apple M0115 (Orange ALPS) - Das Keyboard (Blue Cherry) - IBM Model F - IBM Model M - Dell AT101W (White ALPS) - Cherry POS 8000 (Clear Cherry) - Apple Extended II (Cream ALPS)
Offline Ascaii
  • Trade Count: (0)
WTB: MX Cherry Clear switches, alone or on keyboard.
« Reply #1 on: Thu, 19 May 2011, 13:22:25 »
try pming blainchen over at deskthority, i think he might have some.
Offline BababooeyHTJ
  • Trade Count: (0)
« Reply #2 on: Thu, 19 May 2011, 15:07:06 »
I'm pretty sure that these boards have cherry clears. He accepted my offer for $20 for 2 boards.
Offline Wibox
  • Trade Count: (0)
« Reply #3 on: Thu, 19 May 2011, 15:31:17 »
Quote from: BababooeyHTJ;348651
Seems they often come with MX Browns.. a gamble. I'll give it a try, thanks.
Offline slueth
  • Trade Count: (0)
« Reply #4 on: Thu, 19 May 2011, 15:57:07 »
I have some but I would need to pop em off or I can ship you the keyboard(probably cost more to ship), it doesn't have keycaps though.  I can't ship to you right now since I am busy with school but maybe later I could. Preferably you should be in CONUS.
Offline blainchen
  • Trade Count: (0)
« Reply #5 on: Thu, 19 May 2011, 16:40:56 »
Wibox, don't have any clears left here. (In answer to your pm)
Offline RickyJ
  • Trade Count: (0)
« Reply #6 on: Thu, 19 May 2011, 21:42:26 »
I got mine from him, has clears.  Another member asked him to check all of his boards, and he replied they all have clear switches.
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline Cherry Keyboards
  • Trade Count: (0)
« Reply #7 on: Tue, 24 May 2011, 08:16:05 »
The part numbers for the clear stem (white stem) MX are MX1A-C1NW and MX1A-C1NN. The NW version is for PCB mounting as it has 2 additional mounting pins for added stability. The NN version does not have the extra pins and is designed to be mounted into a metal face plate. For any questions contact Cherry Support at keyboardsupport@zf.com.
Offline Wibox
  • Trade Count: (0)
« Reply #8 on: Tue, 24 May 2011, 13:04:08 »
Thanks for the heads up on that, they are clears. Pictures here: http://geekhack.org/showthread.php?18248-White-KBC-Poker-MX-Clear-Ergo&p=350785#post350785
Offline Niedi
  • Trade Count: (0)
« Reply #9 on: Tue, 24 May 2011, 15:10:29 »
I'm currently offering a barely used, half-year old black G80-3000LQCDE-2 with clears on deskthority. Tried to get used to that keyboard again and again but just couldn't, so it spent a lot of time gathering dust in the cupboard. Switched to browns now and so far I'm pretty happy.
However it'd be 40€ + shipping and it's located in Heidelberg, so it would only make sense if we're on the same side of the ocean ;)
