Author Topic: Ps/2  (Read 2809 times)
Offline PlayerZero
Ps/2
« on: Fri, 20 May 2011, 17:02:40 »
Hey.  I'm hoping to buy my first mech keyboard soon, and I'll likely be getting a Leopold from EK.  So, I noticed it has PS/2 and USB, and I was wondering if there is a way to check for PS/2 ports. (I know I have USB).  I googled it and looked at pics, then checked my PC, and it doesn't look like I have PS/2 ports.  So, is there something i'm missing, and if not, is there some kind of adapter to take advantage of PS/2 even if I don't have the ports?
Extensive research has found your statement to be of inferior quality.  Please revise it.
KEYBOARD:  Leopold FC200RC/AB with Cherry MX Blues
MOUSE:  Logitech G400
Geekhack:  A wiki is worth 1000 threads.
Offline False_Dmitry_II
Ps/2
« Reply #1 on: Fri, 20 May 2011, 17:29:39 »
I think he's asking if there's a way to use the PS/2 protocol if he doesn't even have the port on his computer.
I would say no. No, you can't do that.
Offline PlayerZero
Ps/2
« Reply #2 on: Fri, 20 May 2011, 17:48:16 »
Ok, thanks.  I just read in the Mechanical Keyboard Guide at OCN that PS/2 is better in general, so what would you guys say?  I'm guessing USB is just fine, too. so is there a major advantage to ps/2 or does usb work fine for you geekhackers?
Offline PlayerZero
Ps/2
« Reply #3 on: Fri, 20 May 2011, 17:48:55 »
Quote from: False_Dmitry_II;349173
yep, thats what I was asking.  Thanks
Offline HaveANiceDay
Ps/2
« Reply #4 on: Fri, 20 May 2011, 17:54:05 »
Quote from: PlayerZero;349181
Generalization is commonly used as a substitute for knowledge. The only advantage would be NKRO but that is also possible trough USB with certain controllers, so...
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
Offline PlayerZero
Ps/2
« Reply #5 on: Fri, 20 May 2011, 18:02:56 »
Quote from: PlayerZero;349183
OK, thanks.  Sorry if I sound dumb... I'm just getting into this keyboard thing
Offline PlayerZero
Ps/2
« Reply #6 on: Fri, 20 May 2011, 18:04:38 »
Quote from: HaveANiceDay;349185
Ok, thanks.  Sorry if i sound kind of stupid... I'm just getting into this keyboard thing
Offline Mr. Perfect
Ps/2
« Reply #7 on: Fri, 20 May 2011, 18:17:21 »
Unless you have some specific reason to use PS/2, don't bother. Most new motherboards either don't come with a PS/2 port, or come with one that doesn't adhere to the PS/2 specs(that's the list Ripster is compiling). Leopold boards can achieve 18KRO on USB, so that will work just fine for people with fewer then 18 fingers.
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Ps/2
« Reply #8 on: Fri, 20 May 2011, 19:13:55 »
Quote from: PlayerZero;349193
Because my posts are mostly concise they may appear a bit condescending and flat out unfriendly, but they are not meant to be :)
Well, most of the time at least!
Also, there is some irony in my post.
Offline BaconKnight
Ps/2
« Reply #9 on: Fri, 20 May 2011, 19:28:52 »
Yeah, only benefit to PS/2 usually is NKRO (can press every button on the keyboard at the same time and it'll register). Some keyboards through USB can only achieve 2KRO which could hurt during gaming. Most higher quality mechanical boards or gaming boards achieve 6KRO through USB. Leopold advertises 6KRO but Ripster found out that it actually has 18KRO through USB which is probably way more than anyone needs honestly. Great thing too is that usually keyboards with over 6KRO over USB don't work on Macs but my Leopold works fine on my Macs at work.
Leopold FC200RC/AB
Noppoo Choc Mini
TG3 Data911
Cherry G80-8113LRCUS
IBM Model M 1391401
SIIG Minitouch 1903
Dell AT101W GYUM90SK
Image Gallery
Offline PlayerZero
Ps/2
« Reply #10 on: Fri, 20 May 2011, 20:56:44 »
Thanks everyone!  Especially to ripster for finding 18KRO on this board, so my only worries are aliens wanting to borrow my keyboard...
Ps/2
« Reply #11 on: Fri, 20 May 2011, 21:07:09 »
Quote from: PlayerZero;349262
I'd be more concerned about those anal probes!
Offline PlayerZero
Ps/2
« Reply #12 on: Fri, 20 May 2011, 21:22:27 »
Quote from: ripster;349266
I wasn't the first to find out the keyboard was 18KRO. IIRC Kalyrh was.
 I just say it all the time at OCN to annoy the Mods trying to sell the OCN Ducky keyboard.
Ok, well thanks to him/her then, and still thanks to you for replies (it seems from reading threads that you spend most of your life on this forum =)
Offline PlayerZero
Ps/2
« Reply #13 on: Sat, 21 May 2011, 06:59:53 »
Quote from: ripster;349274
Gotta do something while the porn is loading.
Actually my wife is watching Mary Hart retire.  Nice legs!
lol...
