Author Topic: Interest Check for Blank Colored Modifiers (modeled after OTD.kr)  (Read 43989 times)
Offline noodles256
  • le legendary
Update 2:
Due to the substantial difference between lettering and blank. This will be a group buy for blank keys (shift, alt, and control)
I understand if you want to back out. Please log your interests however if you would like to purchase a set of blank modifiers.
However, I won't mind leading the group buy for the white lettering if enough people log their interests for that.
P.S. pricing for black lettering is the same as the pricing for white lettering
Pricing Update:
Pricing for blank keycaps is as follows:
25 sets          $26.98 / set
50 sets          $15.21 / set
75 sets          $11.63 / set
100 sets        $9.85 / set
150 sets        $8.06 / set
200 sets        $7.16 / set
Pricing Update:
Pricing for this set of 6 keys with white lettering is as follows:
25 sets          $52.00 / set
50 sets          $28.53 / set
75 sets          $21.38 / set
100 sets        $17.80 / set
150 sets        $14.22 / set
200 sets        $12.43 / set
Update:
1. Alt and Control Modifiers will be 1.25 sized so they can fit Filco/Das/Ducky.
2. 2 Shift keys sizes: 2.25 and 2.75, standard Filco/Das/Ducky
Colors will be:
RR for Control
VCS/VCM for Shift
BFN for Alt
- Feel free to make color suggestions.
- special thanks to Dox for keycap sizes =]
Pictures:
Credits to OTD.kr for good picture and keycap design
OTD
Signature Plastics Colors
Credits to fssbzz for this
90b780bd
« Last Edit: Tue, 31 May 2011, 14:34:06 by noodles256 »
AF | Ducky YOTD |
Offline DaemonRaccoon
Interest Check for Colored Modifiers (modeled after OTD.kr)
« Reply #1 on: Tue, 24 May 2011, 18:18:06 »
Looks more like BFN to me, but the white balance might be off.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline cactux
  • Topre Knight
« Reply #2 on: Tue, 24 May 2011, 19:35:20 »
Count  me in for 2 of each, as long as they are suitable for my FLICO Majestouch 2. BTW how much do you think it will cost this time to ship to Australia?
« Last Edit: Tue, 24 May 2011, 19:37:54 by cactux »
[FS]☠ The temple lol ->HERE<-
Offline chuckading
« Reply #3 on: Tue, 24 May 2011, 19:36:18 »
I'm interested, how will this look on a filco? are the size of the modifier's correct for the 87 key board? Any chance font/character layout could match Round 3? or have the option to get a set that matches round 3 MO?
« Reply #4 on: Tue, 24 May 2011, 19:37:55 »
Will the Alt and Control keys be 1.25 (as on a Filco, Leopold, etc.) or 1.5 (as in the photo) keys wide? Also how much will this cost me?
Offline noodles256
  • le legendary
« Reply #5 on: Tue, 24 May 2011, 19:40:41 »
Quote from: chuckading;351003
Font will be standard and it should fit any tenkeyless board. The modifiers on the "STANDARD" if I am not mistake are also regular sized and use the standard filco-esque font.
Main problem is if it will match the standard set (colorwise) well.
AF | Ducky YOTD |
Offline cactux
  • Topre Knight
« Reply #6 on: Tue, 24 May 2011, 19:56:35 »
Quote from: noodles256;351006
Do you think is possible to request a sample, to make sure that everything is okay?
Offline reaper
« Reply #7 on: Tue, 24 May 2011, 20:20:40 »
I'm definitely interested but of course, depending on the price and colors offer.
Din Eli
Offline noodles256
  • le legendary
« Reply #8 on: Tue, 24 May 2011, 21:09:22 »
just sent the quote request to SP, should be expected reply in the next couple of days
AF | Ducky YOTD |
Offline Cata1yst
« Reply #9 on: Tue, 24 May 2011, 21:28:23 »
Interested if it fits a filco.
Offline Dox
« Reply #10 on: Tue, 24 May 2011, 21:39:12 »
Interested too!
ErgoDox x2 | DoxKB x2 |   IBM SSK   | HHKB pro2
Offline calavera
« Reply #11 on: Tue, 24 May 2011, 21:40:02 »
I will be in for several sets IF there are two kinds of RGB sets. One as pictured above which actually WON'T fit filcos, and one that do. So basically both 1.25 and 1.5 RGB sets. Otherwise you're alienating a lot of regular tenkeyless users since the 1.5 is for a win keyless version which isn't really mainstream.
Also is it just me or does the font alignment on the RGB pictured seem random? Control seems more centered than the Alt and Shift.
Offline noodles256
  • le legendary
« Reply #12 on: Tue, 24 May 2011, 21:44:36 »
The modifiers are 1.25? I was sure they were 1.5
Do you know how long the shift key must be?
AF | Ducky YOTD |
Offline Brummell
« Reply #13 on: Tue, 24 May 2011, 21:55:50 »
I'm in for a couple of sets.  It wouldn't bother me if the ALT were a little darker than that, maybe BFK?  I'm good with whatever everyone else wants though.
Unicomp Space Saver | Filco Majestouch Blue | IBM Model M | Filco Majestouch Brown | Realforce 86UB | Leopold Blue | HHKB Pro 2
Offline cactux
  • Topre Knight
« Reply #14 on: Tue, 24 May 2011, 21:58:02 »
The shift keys in my Flico have different sizes
Offline Dox
« Reply #15 on: Tue, 24 May 2011, 21:58:05 »
modifiers= 1.25 units
left shift= 2.25 units
right shift= 2.75 units
Offline noodles256
  • le legendary
« Reply #16 on: Tue, 24 May 2011, 22:10:03 »
Quote from: Dox;351088
thank you Dox!
These are for filco/das/ducky correct?
AF | Ducky YOTD |
Offline Dox
« Reply #17 on: Tue, 24 May 2011, 22:16:50 »
yes
Offline StinkyTofu
« Reply #18 on: Wed, 25 May 2011, 00:04:11 »
Simple & colorful! I would be interested in one set!
Leopold TKL (BR) / SteelSeries 6Gv2 (BL) / Kinesis Advantage (BR) / Poker (RD/on-order)
Offline calavera
« Reply #19 on: Wed, 25 May 2011, 00:05:37 »
You should have no problem getting 30 buyers for the two different sets as I'm sure a lot of people will be buying multiple sets. One RGB set for filco/das/ducky and one RGB set for win keyless.
Offline chuckading
« Reply #20 on: Wed, 25 May 2011, 00:09:32 »
Also, since these keys will be made by SP, are you planning to use the DCS?(I think it's called that) profile that Group 1 and Group 3 MO sets were made with? If so..., please note, these will look super crappy being a different profile than stock filco/ducky etc. keys once placed on a board with stock keys.  They would ideally fit on a board with existing SP keys of the DCS profile.  I think the font should match group 3, group1, or blank. I think offering all three would also beneficial. I'm betting most of your orders would be for the set that matched Group 3's MO. Anybody else?
Offline Mr. Perfect
« Reply #21 on: Wed, 25 May 2011, 00:29:15 »
Right justified font? The picture shows left justified and most keys are left justified(IE, the text starts on the left edge of the key).
Random thought: I like how "Control" is actually spelled out, not shortened to "Ctrl". Would "Alternate" fit on the "Alt" key?
« Last Edit: Wed, 25 May 2011, 00:31:34 by Mr. Perfect »
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline noodles256
  • le legendary
« Reply #22 on: Wed, 25 May 2011, 00:35:34 »
my mistake on right justified, I actually meant left lol
if there is to much discrepancy, they will probably be blank.
calavera - are the measurements different for win keyless?
if the measurements are to different, I am only going to stick with getting a Filco/Das/Ducky compatible set
« Last Edit: Wed, 25 May 2011, 00:38:44 by noodles256 »
AF | Ducky YOTD |
Offline calavera
« Reply #23 on: Wed, 25 May 2011, 03:28:54 »
The win keyless are wider of course. So yes they're different.
Just have TWO options. No alternate fonts, no different wording, no stupid starcraft logos and all that bs.
1x RGB set for filco/das/ducky/poker with fonts or no fonts. (forgot about the poker)
1x RGB set for win keyless with fonts or no fonts.
Although there is far less demand for the win keyless ones, people should keep in mind that the win keyless alt and ctrl fit noppoo choco mini's. The right shift obviously doesn't.
But see how many are interested in each and if one comes up short, ditch it. (It'd be neat if the RGB set for filco/das/ducky/poker included win keyless alt and ctrl though lol)
I have a feeling the win keyless won't be that popular.
Keep it simple so we can move this quick.
Also, shamelessly taken pic from sixty's thread in deskthority:
I'm not sure how similar the color is to the OTD one but I prefer the above but with white fonts.
« Last Edit: Wed, 25 May 2011, 03:44:09 by calavera »
Offline explicit
« Reply #24 on: Wed, 25 May 2011, 06:38:13 »
I would be interrested in a couple of sets, but would prefer if you added a 1.25 left shift for all the ISO-keyboards out there. Just make every set include both kinds of shifts?
Offline sixty
    • http://deskthority.net
« Reply #25 on: Wed, 25 May 2011, 07:13:39 »
I made up these colors with OTD member Uranium about two months back or so and ran a group order for them here.
The first batch that Signature Plastics delivered was messed up and had randomly bold and centered legends. You can see that on the OTD pics on the Control key. The bad news is that they ran out of the blue plastic with no restockplanned, so you will not be able to make the exact same keys anymore. All the blues they have now are a very different shade.
Anyway, for some eye-candy here are the final pictures I took the other day of the final keys:
Offline calavera
« Reply #26 on: Wed, 25 May 2011, 07:20:01 »
Still desperately waiting for you to PM me with good news over at deskthority. I go there a few times every day to be disappointed there's no message.
Offline sixty
« Reply #27 on: Wed, 25 May 2011, 07:28:20 »
Quote from: calavera;351216
When your office table looks like this...
..**** can take a while to sort out :D
Offline calavera
« Reply #28 on: Wed, 25 May 2011, 09:13:56 »
How hard could it be? Get on with it! :D
Offline keyboardlover
« Reply #29 on: Wed, 25 May 2011, 10:00:48 »
Reminds me of this Italian restaurant near me - occasionally they are "out" of things like "pizza" and "olive oil" and "parmisian cheese".
Offline soulfree914
« Reply #30 on: Wed, 25 May 2011, 10:22:12 »
Anyone want to add a 1.75 right shift for Noppoo Choc Mini - style keyboards?Geez.. I desperately need one.
A proud member of OTD & GeekHack
Offline mikeruth
« Reply #31 on: Wed, 25 May 2011, 11:09:45 »
I will want two sets (one each for my Filco and Leopold), depending on final colors ans price.
Mike R.
Offline jblack801
« Reply #32 on: Wed, 25 May 2011, 13:21:18 »
I might be up for it if Soulfree gets his way, I'd like some for my Noppoo Choc Mini. But then again, if I'm getting the shift, I might want the 1.0 alt as well.
Offline 7bit
  • MX1A-G1DW
« Reply #33 on: Wed, 25 May 2011, 14:30:07 »
Quote from: sixty;351220
 ^^^ This is lame!
Only so few key caps on your office table.
You should see iMav's house right now!
Quote from: keyboardlover;351265
Maybe, you eat too much!
Quote from: soulfree914;351281
These are already on the list for Round 4!
« Last Edit: Wed, 25 May 2011, 14:33:05 by 7bit »
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline Lpb45
« Reply #34 on: Wed, 25 May 2011, 15:01:26 »
definatley in for atleast 2 sets maybe more depending on the price.
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline gilgam
« Reply #35 on: Wed, 25 May 2011, 15:36:13 »
As usual the ISO whining guy is asking for an Left shift ISO Key ...
Will he ever be heard
Thanks
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
Offline Dox
« Reply #36 on: Wed, 25 May 2011, 17:19:19 »
I would really want a couple of those too! my custom keyboard is using a 1.75 right shift.
Offline calavera
« Reply #37 on: Wed, 25 May 2011, 20:01:25 »
As 7bit said already, the 1.75 shift for noppoos will be available in group buy 4. Which I'd guess would start coming July. :D
Offline noodles256
  • le legendary
« Reply #38 on: Wed, 25 May 2011, 20:05:28 »
Pricing info should be available tomorrow. Looks like interest for the winkeyless version is very small, looking back it only looks like 2 or 3 want it so that will probably not be a part of this order.
Caps will have white lettering. This is 99% certain, will ask if can get the same price in case a couple want blanks or blacks
AF | Ducky YOTD |
Offline explicit
« Reply #39 on: Wed, 25 May 2011, 20:20:56 »
What about that 1.25 left shift for ISO keyboards? Will RGB kit be a part of the next group buy maybe?
Offline calavera
« Reply #40 on: Wed, 25 May 2011, 23:16:25 »
Looks like it's just standard RGB set for filco/ducky/leopold/pokerx with white fonts.
But since SP ran out of the blue plastic, I dunno what that blue should replace them. :(
Offline noodles256
  • le legendary
« Reply #41 on: Wed, 25 May 2011, 23:32:42 »
melissa didn't tell me about the blue running out?
The color blue that I used in the quote request was BFN
AF | Ducky YOTD |
Offline soulfree914
« Reply #42 on: Thu, 26 May 2011, 00:17:38 »
Quote from: 7bit;351378
Awesome!
Offline noodles256
  • le legendary
« Reply #43 on: Thu, 26 May 2011, 11:31:33 »
Pricing info released.
Group buy is more than likely canceled due to pricing unless we can get at least 75-100 orders which I doubt. Update is in OP
AF | Ducky YOTD |
Offline chuckading
« Reply #44 on: Thu, 26 May 2011, 14:23:14 »
7bit, Any chance Round 4 can also have these colored modifiers that'll be consistent w/ Round 3's font?
Offline Lpb45
« Reply #45 on: Thu, 26 May 2011, 14:29:30 »
7bit already said he would be including these in Round 4 the round 3 thread.  SP's pricing on some of this stuff is just ridiculous, we just bought 50,000 keys from them.
« Reply #46 on: Thu, 26 May 2011, 15:31:49 »
Allahu ackbar?
Offline NormaJean
« Reply #47 on: Thu, 26 May 2011, 16:19:59 »
Count me in for 4 sets :D
Offline placebo guy
« Reply #48 on: Thu, 26 May 2011, 17:12:09 »
Hook me up for 1 set.
Leopold TKL MXRed; RF 103U 55G; WASD MXBlack; Unicomp Spacesaver; AT101W; RK-9000 Blue; various Filco
Offline wanabe
« Reply #49 on: Thu, 26 May 2011, 17:17:08 »
i'm surprised that nobody has posted this yet...dt has this exact group buy going on right now.
http://deskthority.net/viewtopic.php?f=11&t=751
