Author Topic: Question about my Omnikey switches  (Read 1277 times)
Offline Avazee
« on: Tue, 24 May 2011, 18:41:35 »
I took the 'H' key off 2 of my Omnikey's just to see if there was a difference (I noticed an audible difference which surprised me), and I think I see a difference in the type of ALPS switch that each one has.  Observe the two images below:
[ Attachment Invalid Or Does Not Exist ] 18553[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 18554[/ATTACH]
One looks like a bright 'white' whereas the other is more off-white/gray-ish.  My question is- is there indeed a difference between these two switches (I definitely hear the difference)?  And if so, is it normal for two Omnikey's to have different switches?
Thanks in advance.
« Last Edit: Tue, 24 May 2011, 18:46:35 by Avazee »
Offline Avazee
« Reply #1 on: Tue, 24 May 2011, 19:09:25 »
Well, two of my keyboards feel/sound the same (the one with the darker white switch), and the third one is the one in the picture above (bright white switch).  That one is definitely has a bit louder clicky sound.
« Last Edit: Tue, 24 May 2011, 19:15:41 by Avazee »
Offline False_Dmitry_II
« Reply #2 on: Tue, 24 May 2011, 20:23:56 »
If it's louder I would say that it is less worn.
