Author Topic: should I wash these clear switches before using them?  (Read 2271 times)
Offline godofdeath
« on: Wed, 25 May 2011, 15:18:35 »
So I am in the processing of unsoldering the clear switches from that cherry board deal.
The switches are yellow in some areas and I was wondering if I should wash them or not before using them.
Offline Arcanius
  • Buckling Spring Lover
« Reply #1 on: Wed, 25 May 2011, 15:26:22 »
Simply: No.
Washing switches will remove the grease, and possibly even corrode the springs. You'd ruin the switches.
Offline godofdeath
« Reply #2 on: Wed, 25 May 2011, 15:29:27 »
o i was only thinking of chucking the clear piece not the whole thing
but ok
Offline BiNiaRiS
« Reply #3 on: Wed, 25 May 2011, 15:33:01 »
If they are yellowed i would assume that washing them wouldn't really do much.
At the same time though if you are just washing the clear portion of the switch only i don't see how it could hurt. Maybe just a hot water rinse?
KMAC 2 w/ErgoClears
Offline Atenacius
« Reply #4 on: Wed, 25 May 2011, 20:49:39 »
Will that retr0bright work for it or is it only for ABS plastics?
Keychron Q6 GATERON G PRO YELLOW
Vortex Pok3r CHERRY MX RED
Das Keyboard Model S CHERRY MX BLUE
IBM Model M
1391401 09 MAR 93
Offline Tony
« Reply #5 on: Wed, 25 May 2011, 20:58:05 »
Not all keyboards can be washed. They are made so cheap that you can throw it away when it's dirty
Offline Zet
« Reply #6 on: Wed, 25 May 2011, 21:28:56 »
I wouldn't run the chance of loosing or wasting them about this, in the end, the keycap is what matters esthetically right? if the switch works fine I don't see a reason for taking the risk.
Before doing something directly to the switches, ask and search around for a right way to do it, don't rush into water.
Offline godofdeath
« Reply #7 on: Wed, 25 May 2011, 21:51:47 »
so its yes, no, throw in sink with soap like the gigabyte motherboard, and pee on it?
