Author Topic: Blank ALPS keys, UK  (Read 3816 times)
Offline GLaDOS
Blank ALPS keys, UK
« on: Thu, 26 May 2011, 13:49:04 »
Hey guys
I have recently bought an AT102W for £1 from some clueless computer shop owner.
Even after bleaching, however, the keys (including the grey ones!) are a bit yellowed. I tried to bleach the keys but to no avail. I wonder if it would be possible to buy an entire set of blank UK ALPS keys for it, in beige and in possible having the grey keys still grey. Does anyone know of a supplier of such keys?
Thanks
Offline kaiserreich
  • HHKB Elite
Blank ALPS keys, UK
« Reply #1 on: Thu, 26 May 2011, 13:53:01 »
Read the WIKI for Retrobrite/Retrobright/Retr0bright
What I did to return my keys to white from yellow, was to buy a bottle of developer from my local hairdresser with 12% hydrogen peroxide (h2o2), apply generously, and left them in the shade in my backyard. Did a mistake by leaving them under the sun, they don't work when they are dry.
Offline GLaDOS
Blank ALPS keys, UK
« Reply #2 on: Thu, 26 May 2011, 14:28:51 »
Okay thanks, I'll check that out - but I'd still like some blank key caps if anyone knows where. I intend to switch to COLEMAK and it will stop me from looking at the keys as I type. I can type fast but I often look so having nothing to look at would be helpful :P
Offline False_Dmitry_II
Blank ALPS keys, UK
« Reply #3 on: Thu, 26 May 2011, 18:27:50 »
Will there be cake?
@kaiserreich
So it went well with the dell you got?
Offline kaiserreich
  • HHKB Elite
Blank ALPS keys, UK
« Reply #4 on: Thu, 26 May 2011, 21:35:52 »
The switches on my Dell was gritty, the backplate was rusty. Had to open everything up to repaint the backplate, which was the learning experience itself, but as to greasing the switches, I need some proper tools. Opening the switches has be a total pain in the behind without any precision screwdrivers.
Offline hoggy
  • * Ergonomics Moderator
Blank ALPS keys, UK
« Reply #5 on: Thu, 26 May 2011, 23:52:22 »
You should be able to rearrange the keycaps on that 'board.  I haven't seen any blank alps compatible caps anywhere (but then I don't get out much).
Offline GLaDOS
Blank ALPS keys, UK
« Reply #6 on: Fri, 27 May 2011, 05:14:14 »
Quote from: False_Dmitry_II;351833
Will there be cake?
 Umm... yes... lots of cake.... when you finish testing..... yeah, there'll be a party too.... just go and test...
Quote from: hoggy
I can't rearrange the keys, they are slightly angled :/ Plus then the home keys would go too.
I'm gonna see if I can get some peroxide though.
Offline domin8r
Blank ALPS keys, UK
« Reply #7 on: Fri, 27 May 2011, 07:59:20 »
@GLaDOS let me know how that peroxide works out!
I'm in a similar situation.. bought an AT102W for a few bucks too.. But mine has a funky swedish layout (can't complain for that price though) so would prefer to have blank keys too :)
Compaq MX-11800, Ergo Clear/Brown/Ghetto Red
Ducky 1087XM
Laser SX-25 , White SMK
Black Dell AT101W
IBM Model M 1390120 (\'86)
Cherry G80-1000, Panda Clears
