Author Topic: best place to order filco ninja and wrist rest?  (Read 2002 times)
Offline skuzzzzy
« on: Fri, 27 May 2011, 13:48:03 »
http://www.hksuntec.com/filco/majestouch-ninja/majestouch-ninja-fkbn87ml-efb2.html
only place i found that sells it, and im looking to order this tonight, is that the best price/place to order it from?
also where best/cheapest place to order a rist wrest to go with that keyboard?
« Last Edit: Fri, 27 May 2011, 13:57:57 by skuzzzzy »
Offline BigWopHH
    • http://www.hothardware.com
« Reply #1 on: Fri, 27 May 2011, 15:13:28 »
Are you sure that seller has them in-stock?  I'm pretty sure the availability date isn't until June 16.
  • Topre Realforce 103UB
  • Topre Realforce 87U
  • ABS M1
  • Solidtek ASK-6600U
  • Dell AT101W
  • Das III Pro
  • Scorpious M10
  • Cherry G80-3000LSCRC-2 (Blues)
  • Cherry G80-3000LXCEU-2 (Browns)
  • Unicomp Customizer 104
  • Steelseries 7G
  • Filco Majestouch FKBN104M/EB < Has Become My Daily Driver. Really Diggin\' It.
[/SIZE]
Offline skuzzzzy
« Reply #2 on: Fri, 27 May 2011, 15:49:55 »
not sure.
Offline dreamingftw
« Reply #3 on: Fri, 27 May 2011, 15:51:15 »
The web allows me to add it to my cart... I wanted to order this but cherry browns. From the picture, they look like blacks.
Offline dreamingftw
« Reply #4 on: Fri, 27 May 2011, 15:55:34 »
nevermind... i added the browns to my cart... just wondering if anyone has bought anything from this website. is this legit?
