Author Topic: What interface do old sun keyboard use  (Read 2582 times)
Offline journeymangeek
« on: Fri, 27 May 2011, 20:43:37 »
For some reason i have the keyboard off a sun ultra 5 (the rest of it got left behind in a move, on account of it not working, and not being worth shipping home), and it uses an odd interface - a round plug, 3 pins on the first row, 3 pins with a space before the rightmost pin on the second and 2 more pins on the last row. It also has the option to daisy chain the mouse off the keyboard - the plug end looks eerily like a S-VHS port
Is this a reconfigured PS/2 or some crazy custom interface?
Offline DaemonRaccoon
« Reply #1 on: Fri, 27 May 2011, 20:48:25 »
It's a custom interface, See here on how to build an adapter, it's the Sun 4/5/6 interface.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline theferenc
« Reply #2 on: Fri, 27 May 2011, 21:34:34 »
It's pretty custom, yes. What's even weirder is that for a while on their Ultra 5s, they were using a physically identical plug to PS/2, but totally different signaling and power lines. It was really annoying.
Adapters do exist for sale, or at least they used to (in the late 90s I had a few) but as DaemonRaccoon posted, you can just build your own. It isn't that hard. We did that a few times as well.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #3 on: Fri, 27 May 2011, 21:42:42 »
I got the document from the Sun site that explains the interface. It is unusual in that it's more like a conventional serial interface than that of most keyboards. Ordinary keyboards are bit-serial as well, but they're very different from RS-232.
Offline kps
« Reply #4 on: Mon, 30 May 2011, 09:23:04 »
Quote from: journeymangeek;352252
>Implying PS/2 isn't a crazy custom interface.
