Author Topic: G80/G81 3000/8000 keycaps fit on what else?  (Read 1443 times)
Offline BiNiaRiS
« on: Sun, 29 May 2011, 22:13:30 »
I know most of these keys fit on, but what keyboards do the modifiers fit on? Filco? Das? Leopold?
KMAC 2 w/ErgoClears
Offline BiNiaRiS
« Reply #1 on: Tue, 31 May 2011, 14:16:03 »
yeah?
KMAC 2 w/ErgoClears
Offline Arcanius
  • Buckling Spring Lover
« Reply #2 on: Tue, 31 May 2011, 15:12:24 »
Some keys will work, some won't. Filco Das and Leopold are identical in key profiles, except that Leopold has a different spacebar. Ctrl, Alt, will work. Left shift, Num0 and Enter might as well, but right shift and Caps Lock are dubious.
